As above, but when doing bikeparks, especially BPW i take all compression off the fork and slow down the rebound to make it better for small hit stuff.
But, as always, you just get fatigued, the blues at BPW are pretty much long and bumpy, especially if you hit the likes of sixtapod, willy waver, terry’s belly, etc. They’re fast riding and do kill the arms after a while. If you have arm tension then you will fatigue faster, it just takes a good bit of practice and riding to be able to loosen off the arms and let them soak up some of the shock, or not having the deathgrip on some descents, it’s what gets me at times, don’t even know i’m gripping so tight at times.
