I’m finding they haven’t got enough power, they don’t bite strong enough to lock up really with 1 finger braking
Your bleed is wrong, pad alignment is out, pads are contaminated… Or some other reason. There’s no reason that a properly bled set of Guide Rs shouldn’t lock up easily with one finger braking.
Before buying new Guides, I’d track down the problem you have with your current set. It would be cheaper to pop to your LBS and get them to sort it, than buy new brakes and throw these ones in the sea.
I’d switch out the pads, and give the rotors a clear with some IPA. I’d also check how thin the rotors are, compare them to the centre part that doesn’t wear against the pads.
I’ve got R, RS and RSC and Hope E4. The Guide R have more obviously available power than the E4s. It’s not that the Hope aren’t powerful, they’re just linear in how they deliver it.
