Regardless which cutters you use it always crushes the ends in
True that. My (Birzman) cutters have a handy little bradawl incorporated in the side of the tool, recessed into a round socket so you press the cut cable-end in and open it back out.
Back to the ‘are all cables equal’ – I hope not as last week I paid LBS £40 for what I thought was a full set each of Avid (brake) and Shimano (gear) inner and outers, yet still had to reuse an old brake cable as the Avid set only had one long outer and that wouldn’t run the full length of both brakes. Guess it was intended to be cut for interrupted runs with cable-stops, which my frame (Mk1 Longitude) doesnt have.
Anyway, forty quids for 3/4 of the job. Am I getting too old for this game? How can a pint be £4? Etc… 🤣
I do think Shimano steel cables seem to run slightly smoother/more friction-free than various Teflon-coated ones* although both work well IME. The possible trade-off is the Teflon ones seem to go on longer with that ‘fresh’ feel without the need to replace.
*Have used Avid Flak Jackets and Clarkes Premium in the past
