Yeah, I built a 14″ on up for my 9yo a few months ago (well, actually I got him to build it, I just did a couple of tricky bits). Attention SL if I recall, though I think several of them are the same frame. 26″ wheels with 2.2″ish tyres, 150mm cranks, narrow flat bars and an old 26″ Marzocchi Bomber fork.
As above: it looks quite short. With a 50mm stem it already looks a wee bit small. And the front end does end up steep by modern standards, but I’m stuck in the 90s so it looks broadly ok to me 😉
I ran into two build issues: one was that the rear end wouldn’t take a BB7 brake due to the compact rear triangle, so I had to sell those and get some Shimano hydraulic brakes (I looked up the original spec of the full bike and went with that to avoid repeating the problem). The other was that I had no idea about direct mount rear mechs and had to buy a new one.
The seat clamp seemed a bit tetchy: I bought the supposedly matching Cube QR clamp but I couldn’t encourage it to actually go over the seat tube; in the end I luckily had a non-QR one in the spares box which just about fitted.
Also I think I’ve got a cable ferrule (or two) stuck in the recessed stops in the frame, so I’d suggest not using ferrules there. Possibly obvious to some people, I dunno.
Other than that, it all seems jolly good. My wife had a go on it and immediately declared it far better than hers. Not least because the 26″ wheels on a 27.5″ frame puts the BB an inch lower than on her bike.
