Viewing 13 posts - 1 through 13 (of 13 total)
  • Any way to protect a Hope Pro 2 Freehub?
  • rob-jackson
    Using a sram 990 cassette, is their any wany i can protect it from gouging – New set of wheels?
    flow
    Don’t worry about it.
    SBrock
    yeh get a steel one, but i wouldnt worry about doesnt really cause that much damage!
    FraserHughes
    You can buy tougher (but heavier) Steel hub bodies.
    Probably more expensive than a splined cassette though!
    EDIT: beaten by 11 seconds 😳
    neninja
    I have heard of people straightening steel staples and running them along the splines to protect them
    z1ppy
    You can get a steel version of the freehub if your ‘that’ worried.
    Wasn’t there a thread where some-one had added steel bits in front if the spline, no idea how they fitted tbh.
    In all honesty I’ve used a mixture of cassettes on mine & though it has ‘damage’, it not anywhere near enough to contemplate replacing it (4 years old at a guess).
    xraymtb
    I thought the issue was only with steel cassettes? The 990 is an alloy spider so shouldnt do any damage?
    That said I’ve been running a steel cassette on mine for years – you can see the marks but it would have to be ten times worse before I change the freehub.
    Northwind
    Yep, 990 is an alloy spider. The un-spidered cogs will still eat the freehub oer time though.
    Thing is… You can buy a steel freehub. Or, you can just ignore it til it becomes a problem, which takes a very long time, and then buy a new freehub.
    flow
    I just took a Deore cassette off my bike, been on there from new, about 6 months, not even a mark on the free hub.
    nosedive
    I think it is the smallest 2 or 3 cogs that aren’t on the spider? I found over about 3 years it did mark the freehub quite a lot. but by then you will probably find that the bearings are shafted and you may have broken some springs. £50 for a new steel freehub body with new bearings in and new pawls and springs doesn’t feel so painful 3 years later.
    retro83
    neninja – Member
    Yes I’ve seen this on weight weenies forum. Did have a picture but can’t find it now. Looks like a reasonable bodge solution.
    Edit: see my post on this thread: http://www.singletrackworld.com/forum/topic/dear-oh-dear-pro2-content#post-2144728
    bigjim
    That staple bodge isn’t a hope freewheel body though. I guess you could machine down the freewheel so you could fit a staple in if you have the resources but as far as I can see you can’t do it like that on a hope.
    njee20
    Just get on with it. An XX/XG999 cassette is the only one that won’t mark it, and they’re more than a whole new pair of hubs.
The topic ‘Any way to protect a Hope Pro 2 Freehub?’ is closed to new replies.
