The kids were pestering me about making the van into a party bus – i.e. making the stereo louder – and so with an old 10″ sub I had in the attic from my boy racer days I thought I’d just wire up an amp and that would be it.
Bought a little Vibe Powerbox 400.1, should be good for about 170W RMS at 4ohms, wired in with 8 gauge direct from the battery and with a 60amp fuse inline. The sub I had was an old Vibe Slick s10, rated for 350W RMS at 4ohms. Underpowered a bit but should work. And it did, for about 2 minutes. I’ve checked with a multimeter and it seems OK, around 3ohms resistance across the terminals but just no sound. I put it down to just been too old so sense-checked everything else and bought a cheap Juice sub. Same deal, 4ohm sub rated at ~300W RMS. This one worked longer but has also gone on the blink, this time the multimeter is showing infinite resistance.
The amp is giving out a signal as it works if I connect a standard car speaker, but wondering if it might be knackered and somehow overloading the subs, but I’m not sure how that would be the case when it’s only around 1/2 the rated power of the speakers. Before I go throwing any more money at it, what am I missing? Other than the fact that this is a massively chavvy undertaking…
