Can you define what you mean by ‘not right’?
Did he ‘crank up the volume’ momentarily, or for an extended period of time. You can normally get away with it for a momentary wallop, but if it was for a prolonged period he might have done some daamge.
If the amp was clipping for prolonged periods then he could have damaged the speakers.
Is it both speakers? If it’s only one you can swap them around to check whether the fault moves with the speaker (speaker fault) or stays where it is (amp fault).
Have any of the tone adjustment options been fiddled with, which might be making it appear that something isn’t right?
