Ok, bear with me. SLX shifters, XTR rear mech and 9 speed SLX cassette. Outer cable falling apart and the shifter managed to munch the cable, so i decided to put in some new Mudlover cable.
Managed to index the gears from H to L, but when changing from L to H the changes are just not happening or very poorly especially off the largest cog. Why?
I’ve tried a new XT mech but the issue is still there so it can’t be a bent mech and the hanger looks straight. I’ve also played around with L limit and B screw. Turning the barrel adjuster clockwise improves things, but then the H to L shifting is not as sweet.
What i have noticed is on indexing H to L it takes a fair few turns of the barrel adjuster for the shifter to shift onto the second cog. Then to ghost shift against the third cog, requires a fair few turns more before turning clockwise to stop the rattle. Another time, i don’t know why, but after messing around, the first shift was almost fine without any barrel adjustment, although i always check the cable is pulled through to the pinch bolt.
