5m x 5m can be quite a levelling job for the uninitiated. Levelling compound starts to cure a lot more quickly than people think. Depending on how much you want to throw at it…a few suggestions:
Have a few yellow builders buckets and mix a few bags at a time – if you can cajole a mate into helping – he or she can do the mixing and washing out while you’re pouring and spreading.
To help flow, I’d probably always leave a handful of powder in the bag – no more than that!! When you think it’s mixed enough, mix it for another minute or two.
Consider buying a latex rake (google it – readily available) to help spread and keep a consistent depth.
A spiked roller (again google it) helps disperse air bubbles. But this is probably a bit of a luxury.
Not sure how expensive the above two are – might set you back 50 or 60 quid, but if you clean them spotlessly after the job, you could probably shift them on Facebook marketplace afterwards and get some of your money back.
