Our house is three storeys high, and the boiler is on the ground floor but the airing cupboard and central heating pump are on the top floor. All the rooms have thermostatic valves, but the heated towel rails on the top floor bathroom and middle floor bathroom and the radiators on each landing don’t.
When we moved in, the radiator in the hallway hardly heated up presumably because it was the last in line, so no hot water was left. So I throttled back the upstairs hallway radiators and towel rails to almost fully shut to force more hot water down to the ground floor.
This worked, but how do I know if I’ve over-done it. If the water return is too hot I’ll have problems, won’t I? And those non-thermostatic radiators are such because they have to dissipate a certain amount of heat, right?
