Some great responses 😀
slimjim78 – Member
erm, it get’s you a bit further back?
Is about right but you could just as easily say that an inline post gets you a bit further forward.
As with the other thread about ‘correct’ setup, there isn’t a correct answer. A layback post will allow some people to get the right position for them while for others it’ll be pointless or put them too far back.
It’s worth remembering of course that there isn’t a standard for posts as such – layback or inline posts are just as valid and some frames are designed in a way that may suit one or the other (for average proportions) depending on ETT length and/or seat tube angle.
can I buy a 410mm post and then trim it?
Yes, but I wouldn’t bother shortening it unless a) you’re a weight weenie or b) it’s too long for your frame otherwise.
