Help me out please good people of STW – I’m searching for a wheel upgrade and am continually coming up against the same issue:
Nearly all modern hubs are designed so that spokes are located in them alternately either closer to or further from the ends of the hub before going out to the rim. But just about every wheel you look at has the spokes wrapping round each other on the way – ie a spoke that starts nearer the centre of the hub is bent round a spoke that starts nearer the outside; and if you look down the length of the spokes they’re all distorted round each other.
This goes against the wheel building literature that I’ve read that says you should never do this – spokes are designed to pull in straight lines and making them bend round something introduces a focal point for stress and failure. This makes a lot of sense to me, but is contradicted by just about every wheel I see.
So which is right??? Do I keep searching for unimpeded spoke threading, or am I discounting perfectly good wheels unnecessarily?
Thanks!!
