Viewing 4 posts - 1 through 4 (of 4 total)
  • A bit old skool….. rear QR question
  • steve_b77
    I’ve got a CX bike which is QR all round, perish the thought I hear you say, the wheels will fall out Guv, it can’t be stiff etc etc.
    But in all seriousness, its QR135 rear and has mis-matching QR’s will a 130mm qr be ok, or does it have to be a 135?
    YoKaiser
    I wouldn’t and I’m not sure many will say they would. Imo a pair of Shimano qr are cheap and as good as any if not better.
    JonEdwards
    So long as the thread on the QR axle goes all the way through the threaded bit of the nut it’ll be fine.
    (in most cases for max strength, a thread needs to be engaged by its own diameter into a nut – eg a 5mm bolt needs a 5mm deep nut. If you’re dealing with an alloy nut on the end of the steel QR axle, you’ll want a bit more penetration to compensate for the weaker material)
The topic ‘A bit old skool….. rear QR question’ is closed to new replies.
