I should’ve stopped reading at that, as the rest of that is utter nonsense.
Summarising it as “I’d not spend £1k of the budget on something that makes the least difference” any better?
You’d save more weight spending the price difference on other parts than a carbon frame. And it’s suspension/wheels that make you go fast, assuming the frame you want is available in alu and carbon versions of course. And if there isn’t a carbon version of the bike you like?
My Smuggler compared to my Patrol Carbon is so much heavier I haven’t actually dared weigh it. I’d hazard a guess at 33lbs. The Smuggler 4, which is about £3k, is 35lbs.
When I got mine the alternative was a Fuel but none were available secondhand for the right price. They are meant to be really pretty amazing.
I have not weighed my Smuggler buts it’s an XL frame custom built with Ohlins fork LB rims on Chris King hubs Praxis cranks 1×11 setup with 150mm Dropper I love it even if not that light
Here’s another one, unwashed with mismatched rotors and all (got a gold 203 on the way from a nice fella on here)
It’s a 2017, really enjoying it. If you just ride around on it it’s pretty unremarkable really but once you let go of the brakes and put some effort in it is awesome. Makes the trails come alive etc. I was running it in the high position but got used to accounting for pedal strikes and am running it in low. Only situation I wouldn’t is climbs like the first one on the Blade at Afan where it was constantly catching the rock outcrops where you barely have any momentum.
Had a quick swap with a mate’s Camber the other day and was surprised at how different they are, the Camber changes direction at lightning speed but wouldn’t fancy taking it down anything too steep or techy. The Trek felt like a stretch limo swapping back. Also loaned it to a mate of a mate last night, he was all set on buying one of the discounted Intense Carbines from Merlin but is considering one of these now.
Weighed it today, 31.3lbs with LB carbons, Renthals, XT trail pedals and over a KG of Slaughter Grid casing rear tyre which is about what I expected, certainly not disappointed with that.
Hi
I have an Evil The Following and it’s the best bike I’ve ever ridden
New frame and second hand ((but good quality) parts speccd off here and eBay was easily less than 4K.
Built with Fox36 Talas (135/150), XT 1×11, Reverb, Saint brakes, LB/King wheels etc etc.
The Monarch shock is really good but picked up a Fox DPS Kashima shock in Mojo close out sale and it’s even better.
Weight is ~30lb
Ride with the fork at 135mm most of the time but 150mm for big descents eg Garburn Pass.
Would have another in a flash.
I would say consider sizing up though if you’re on the cusp of two sizes.
Steve
gkw – 140mm. I’d like to put a 150 on it, doesn’t really need it but would like to.
Cut the stroke spacer off it the other day so now has 136mm travel by my calcs. Only done 2 properly muddy rides since so hard to say but seems good so far. Also put it back to high setting, it’s slack enough anyway and works better as an all round trail bike IMO
Thanks Steve, I had a go on a friends wreckoning , blinged out with Öhlins front and rear , and thought it was very very nice indeed, but I have ordered a smuggler as a friend runs a bike shop and got me a good package price on a combined frame and fork. I thought the reach on the following was a little short, that was all, prefer the geo on paper of the smuggler. it’s not carbon and I’ve been told it won’t be out for another year at least, so I went aluminium. Currently looking on eBay and here for second hand parts to build it up to a decent spec.
Hi
Interesting what you say about a Wreckoning
Based on my Following I have an itch for one of these as my big bike.
Might use the bits off my Jeffsy in the future to build one up.
Either that or a Trek Slash 9.9 RSP which just “looks right” IMO
Barely ride my Jeffsy since I got The Following. Nothing wrong with it at all, they just overlap but I think the Evil is better as an everyday trail bike.
Steve
Now as said with öhlins, although actually the fork broke and now it’s getting fixed under warranty!
He says ‘cockpit’ but forgive him he’s Swedish so I think he thinks it is ok to say that 😆
