opportune thread. i’ve just last night aired up a set of rangers, same combo as above, on 45 scrapers, with wtb tape and joe’s valves. a lot of reviews said they were difficult to fit, so i entered in to it with a bit of trepidation, but didn’t find them too bad at all TBH. i was pretty slack about how i fitted the tape, so there wasn’t much of a well for them to drop in to, but they went on ok with a little persuasion from a pedros tyre lever. the more awkward of the two was the light one – it’s so flexible you try getting a bit more tough with one bit of it and the other bit just peels straight off. i found that if i held one side on, and just worked on the other side bit by bit with the lever, it was good.
they aired up with a regular track pump easy, though both leaked at a particular spot on the rim – where the joint is perhaps. the sealant fixed both though, and they’re both holding air this morning.
pimp – what terrain/pressure are you riding?
alex – what sort of terrain are you riding?
i don’t think i can go too low pressure with these, they’re going to roll if i do.
