<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Why can&#039;t a GPS work out altitude ? - Chat Forum				            </title>
            <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sat, 04 Apr 2026 20:30:59 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: Why can&#039;t a GPS work out altitude ?</title>
                        <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312349</link>
                        <pubDate>Wed, 10 Jul 2013 17:49:13 +0000</pubDate>
                        <description><![CDATA[I&#039;ll certainly concede that altitude lost/gained may well be open to all sorts of cumulative errors while the device, whatever it is, tries to maintain its contact with the satellites. It&#039;s ...]]></description>
                        <content:encoded><![CDATA[<p>I'll certainly concede that altitude lost/gained may well be open to all sorts of cumulative errors while the device, whatever it is, tries to maintain its contact with the satellites. It's different to standing in one spot while the device settles down. Putting barometric sensors into phones/pads would be a useful addition, seeing as how they're being used more and more for outdoor pursuits where accuracy is needed.
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>CountZero</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312349</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312348</link>
                        <pubDate>Wed, 10 Jul 2013 17:27:57 +0000</pubDate>
                        <description><![CDATA[I fly hot air balloons for a living and use a GPS iPad and an altimeter/variometer.  The altimeter/variometer uses barometric pressure and is by far the most accurate.  If you can find a GPS...]]></description>
                        <content:encoded><![CDATA[<p>I fly hot air balloons for a living and use a GPS iPad and an altimeter/variometer.  The altimeter/variometer uses barometric pressure and is by far the most accurate.  If you can find a GPS that fits your needs and has a barometric sensor then your in business.
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>sparkyspice</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312348</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312347</link>
                        <pubDate>Wed, 10 Jul 2013 12:29:34 +0000</pubDate>
                        <description><![CDATA[Endo can be all over the place. I record my commute and always take the same route and my Total Ascent varies between 100 and 300m!
And if you try importing a GPX from a Garmin then you can ...]]></description>
                        <content:encoded><![CDATA[<p>Endo can be all over the place. I record my commute and always take the same route and my Total Ascent varies between 100 and 300m!</p>
<p>And if you try importing a GPX from a Garmin then you can get some very odd figures (mate had one where it looked like it was reporting the ascent in feet as if they were metres - resulting in an ascent three times higher than it should have been. </p>
<p>Reported it to Endo Support and they just said they knew there were "some inaccuracies"  :roll:
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>GrahamS</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312347</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312346</link>
                        <pubDate>Wed, 10 Jul 2013 12:04:36 +0000</pubDate>
                        <description><![CDATA[Looked at that before (ye olde worlde thread on here).
Everytrail iirc was one that simply added the +/- differences between every consecutive data point in the file.  Data points were typic...]]></description>
                        <content:encoded><![CDATA[<p>Looked at that before (ye olde worlde thread on here).</p>
<p>Everytrail iirc was one that simply added the +/- differences between every consecutive data point in the file.  Data points were typically at 1s intervals, but several may be missing due to bad lock, etc.<br />
Endomondo iirc smoothed it a bit.<br />
Strava invented some extra relative height differences from somewhere else.<br />
edit: not sure what the eTrex does - think it might be just the sum like Everytrail uses.</p>
<p>The exact same file was used for all 3.</p>
<p>Those spot checks seem pretty accurate, certainly accurate enough.  Mine gives a reasonably consistent +40m offset.</p>
<p>Can anyone explain why my last endomondo trip decided my altitude dropped to 281m below sea level?  The only descent I did was off a bridge crossing the railway about halfway thru a ride. (can sort pic later).
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>andytherocketeer</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312346</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312345</link>
                        <pubDate>Wed, 10 Jul 2013 11:55:14 +0000</pubDate>
                        <description><![CDATA[Count: pretty good for a fixed position but my experience is that Total Ascent/Descent on a route, as recorded by Endomondo, is often waaaaaaay of the mark.
Incidentally, does anyone know if...]]></description>
                        <content:encoded><![CDATA[<p>Count: pretty good for a fixed position but my experience is that Total Ascent/Descent on a route, as recorded by Endomondo, is often waaaaaaay of the mark.</p>
<p>Incidentally, does anyone know if there is some standard way to work out Total Ascent/Descent?</p>
<p>Obviously it is the total of every up/down but at what sort of distance/time resolution?</p>
<p>i.e. the ground is never totally flat, but at what resolution does/should it count towards total ascent/descent? </p>
<p>For example, crossing a road could add 20cm to ascent and descent for the kerbs, plus another say 50cm for going up and down the road camber, but presumably it normally doesn't (partly because the GPS isn't precise enough to detect it).
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312345</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312344</link>
                        <pubDate>Wed, 10 Jul 2013 11:38:25 +0000</pubDate>
                        <description><![CDATA[I thought I&#039;d do a little experiment yesterday, while I was down at Brean, and check my phone&#039;s GPS against the trig point on Brean Down. I took two screen-grabs, one with Viewranger, becaus...]]></description>
                        <content:encoded><![CDATA[<p>I thought I'd do a little experiment yesterday, while I was down at Brean, and check my phone's GPS against the trig point on Brean Down. I took two screen-grabs, one with Viewranger, because it has the proper OS mapping, but doesn't show altitude, and one using UK Map, which shows altitude, but the mapping is more basic free OS.</p>
<p>http://i1015.photobucket.com/albums/af280/AdrianH2010/3a6b90bdd7170f16c4d2f1297dd51444.jpg<br />
http://i1015.photobucket.com/albums/af280/AdrianH2010/400d7e5e42f42f28ee01ce878ad8b1fa.jpg</p>
<p>The trig point is 97m, or 318.24ft, and my phone shows it at 315ft, after it had settled down and aquired enough satellites. Accurate enough for most people, I would think.
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312344</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312343</link>
                        <pubDate>Mon, 08 Jul 2013 23:12:09 +0000</pubDate>
                        <description><![CDATA[As a land surveyor, GPS equipment gets its position by timing signals from itself to a number of satellites,. GPS (US ones) or GLONASS (Russian ones). Your car sat nave does the same, but pr...]]></description>
                        <content:encoded><![CDATA[<p>As a land surveyor, GPS equipment gets its position by timing signals from itself to a number of satellites,. GPS (US ones) or GLONASS (Russian ones). Your car sat nave does the same, but probably not the GLONASS bit.</p>
<p>To get an accurate fix, atmospheric conditions must be taken into account. With my Leica Smart Rover equipment, ( RRP £20,000) I also need to pay for a smart net licence that is IRO £2,000 PA.</p>
<p>This dials into the smart net network via a mobile phone to a series of base stations to enable it to gain accuracy of between 10-15mm. If you have no GPRS phone signal, forget it.</p>
<p>I have other GPS equipment that is only 4m accurate unless its sited over known stations with GPS coordinates. This is essentially your car or bike sat nav but I have 2 that interact by radio with one another to gain fix. Their E an N are still only accurate to 3 or 4m and elevation to 5 or 6 m ( due to atmospheric conditions ) unless told where the base is, either by correction, eg set up, survey, manipulate on drawings like CAD, apply adjustments or as above with a smartnest licence. Or with a previous survey E.g, set up base, apply coordinated, survey knowing you are effectively inaccurate, apply adjustments on the computer later to gain true OS coordinates of base station location and carry on with survey.</p>
<p>My base and rover kit costs over £20,000 new. My Leice kit, similar plus the licence, paid annually.</p>
<p>What do you expect for a few hundred quid from your bike GPS?</p>
<p>Elevation is the hardest to get accurate BTW, E and N, 3-4m generally.
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>coolhandluke</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312343</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312342</link>
                        <pubDate>Mon, 08 Jul 2013 20:26:36 +0000</pubDate>
                        <description><![CDATA[Very good gps tutorial here that will answer a lot of questions - [url]]></description>
                        <content:encoded><![CDATA[<p>Very good gps tutorial here that will answer a lot of questions - http://www.trimble.com/gps_tutorial/
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>bearGrease</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312342</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312341</link>
                        <pubDate>Mon, 08 Jul 2013 17:55:18 +0000</pubDate>
                        <description><![CDATA[The iPad doesn&#039;t have barometric, but its GPS is fairly accurate. This is a screen grab I&#039;ve just taken using UK Map, with OS mapping centered on where I live. The nearest main contour is 60...]]></description>
                        <content:encoded><![CDATA[<p>The iPad doesn't have barometric, but its GPS is fairly accurate. This is a screen grab I've just taken using UK Map, with OS mapping centered on where I live. The nearest main contour is 60m, about 196.8ft, and the GPS is showing 193/196ft, with a +/-16ft error:</p>
<p>http://i1015.photobucket.com/albums/af280/AdrianH2010/5fdef34807d0030b28d2bf2f6f230017.jpg
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312341</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312340</link>
                        <pubDate>Mon, 08 Jul 2013 15:19:24 +0000</pubDate>
                        <description><![CDATA[I used to suffer a similar thing with my 705 on wet rides, turned out it was water blocking the barometric sensor holes, putting a plastic bag over the GPS cured the problem but made the scr...]]></description>
                        <content:encoded><![CDATA[<p>I once did a 10x1mile lap time trial on a summers morning just after a huge rainstorm. My GPS, using its barometric alitimeter, told me I had been steadily descending for 1000 feet. - presumably the air pressure was low, then got higher?</p>
<p>I used to suffer a similar thing with my 705 on wet rides, turned out it was water blocking the barometric sensor holes, putting a plastic bag over the GPS cured the problem but made the screen hard to see.  :roll:<br />
the rubber case thingy for the 800 seems to stop the problem but makes the alarms hard to hear.
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>Dibbs</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/why-cant-a-gps-work-out-altitude/#post-5312340</guid>
                    </item>
							        </channel>
        </rss>
