<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									which finish for red pine? - Chat Forum				            </title>
            <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sun, 05 Apr 2026 01:42:14 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: which finish for red pine?</title>
                        <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379926</link>
                        <pubDate>Sun, 09 Dec 2018 16:13:12 +0000</pubDate>
                        <description><![CDATA[thanks all.  just ordered a couple of Osmo testers to see how they will look.
cheers]]></description>
                        <content:encoded><![CDATA[thanks all.  just ordered a couple of Osmo testers to see how they will look.
cheers]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>pandhandj</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379926</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379558</link>
                        <pubDate>Sun, 09 Dec 2018 09:59:02 +0000</pubDate>
                        <description><![CDATA[What about a distressed look, watered down paint, wiping on and then right back off?
for that you need to have some texture / raised grain otherwise its just really a stain/wash. Practice...]]></description>
                        <content:encoded><![CDATA[<blockquote>What about a distressed look, watered down paint, wiping on and then right back off?
</blockquote>
for that you need to have some texture / raised grain otherwise its just really a stain/wash. Practice on off-cuts first -  a good, stiff wire brush (ideally one you can hold well with two hands) along the grain removes softer material and brings up the grain. You can also sort of burnish that softer wood down - I've used the ball-pien side of a big old hammer - sliding it along the grain it'll track along between the harder grains and raise them up. Both pretty tedious though.Sand-blasting works if you've anywhere local that does it]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>maccruiskeen</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379558</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379548</link>
                        <pubDate>Sun, 09 Dec 2018 09:47:29 +0000</pubDate>
                        <description><![CDATA[Find the Osmo oil finish you like best and use that. I’ll never use danish or Tung oil again after using a couple of their products. So easy to apply and looks great.
They do some tinted Po...]]></description>
                        <content:encoded><![CDATA[Find the Osmo oil finish you like best and use that. I’ll never use danish or Tung oil again after using a couple of their products. So easy to apply and looks great.
They do some tinted PolyAx oil which I’m sure you could get in a grey/black finish which your daughter would like.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>charlielightamatch</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379548</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379489</link>
                        <pubDate>Sun, 09 Dec 2018 08:55:44 +0000</pubDate>
                        <description><![CDATA[Melt down beeswax, cocunut oil and chopping board/mineral oil roughly in equal measure. This produces a robust, non-greasy and clear finish which shows the wood at its best and does not degr...]]></description>
                        <content:encoded><![CDATA[Melt down beeswax, cocunut oil and chopping board/mineral oil roughly in equal measure. This produces a robust, non-greasy and clear finish which shows the wood at its best and does not degrade (foodsafe). Easy to re-apply.
If you decide on oil (Tung's a good one, or Danish) then dilute the first coat 50% with white spirits then get on as many coats as you can (5+?). More of a performance but the finish will be superb.
Should you go down the lacquer route, I find Wilkos lacquer spray (£4) good inside and out, I did some wooden doorsteps and oak washing-line props after oiling and the finish has survived very well indeed.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>BillMC</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379489</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379358</link>
                        <pubDate>Sat, 08 Dec 2018 23:12:25 +0000</pubDate>
                        <description><![CDATA[In my very limited experience, I didn&#039;t like wax at all, that was on oak mind you. Felt greasy to the touch (obvs) and seemed to take away the naturalness of the wood. I&#039;ve got some Danish o...]]></description>
                        <content:encoded><![CDATA[In my very limited experience, I didn't like wax at all, that was on oak mind you. Felt greasy to the touch (obvs) and seemed to take away the naturalness of the wood. I've got some Danish oil left over from the oak, might try that on an offcut in the morning.
Cheers kayak, you posted as I was typing]]></content:encoded>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379358</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379353</link>
                        <pubDate>Sat, 08 Dec 2018 23:09:23 +0000</pubDate>
                        <description><![CDATA[Danish oil]]></description>
                        <content:encoded><![CDATA[Danish oil]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>kayak23</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379353</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379329</link>
                        <pubDate>Sat, 08 Dec 2018 22:35:23 +0000</pubDate>
                        <description><![CDATA[I wouldn’t consider no finish an option, it will take all sorts of stains from oils in your hand and absolutely zero chance of removing marks from day to day life.
If you want to keep the r...]]></description>
                        <content:encoded><![CDATA[I wouldn’t consider no finish an option, it will take all sorts of stains from oils in your hand and absolutely zero chance of removing marks from day to day life.
If you want to keep the raw finish I’d go for an oil finish. You can wax over that if you like, wax is not really a finish on its own.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>goldfish24</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379329</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379260</link>
                        <pubDate>Sat, 08 Dec 2018 21:44:12 +0000</pubDate>
                        <description><![CDATA[If you want to accelerate natural ageing - although its more of an exterior wood look - theres a potion you can mix up that creates the same tannin reaction that happens to wood with age:
F...]]></description>
                        <content:encoded><![CDATA[If you want to accelerate natural ageing - although its more of an exterior wood look - theres a potion you can mix up that creates the same tannin reaction that happens to wood with age:
Fill a jar with vinegar
stick some wire wool in it
leave it to steep (in the shed, its stinky) for a couple of days. Leave the lid loose as it'll give off gas
The resulting smelly solution can be painted onto wood and it reacts in the same way as years of sun and rain would
Red pine is relatively low in tannin but if you leave it out in the sun/rain for a day or two it yellows/darkens a bit as any tannin gets pulled to the surface and that then reacts more <a href="https://www.youtube.com/watch?v=5QDXfmSuGZg">readily with the stink-wash </a>]]></content:encoded>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379260</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379253</link>
                        <pubDate>Sat, 08 Dec 2018 21:37:08 +0000</pubDate>
                        <description><![CDATA[torch it]]></description>
                        <content:encoded><![CDATA[torch it
https://www.youtube.com/watch?v=C3WpYO1vbFc]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>fongsaiyuk</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379253</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379199</link>
                        <pubDate>Sat, 08 Dec 2018 20:50:56 +0000</pubDate>
                        <description><![CDATA[&#x1f923;]]></description>
                        <content:encoded><![CDATA[&#x1f923;]]></content:encoded>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/which-finish-for-red-pine/#post-10379199</guid>
                    </item>
							        </channel>
        </rss>
