<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Confused about car stereo connections.. - Chat Forum				            </title>
            <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sat, 04 Apr 2026 20:32:14 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: Confused about car stereo connections..</title>
                        <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233225</link>
                        <pubDate>Tue, 11 Jun 2013 06:01:21 +0000</pubDate>
                        <description><![CDATA[I&#039;ll never forget my first attempt at wiring a stereo, more chocolate blocks behind the dash than a cadburys factory...]]></description>
                        <content:encoded><![CDATA[<p>I'll never forget my first attempt at wiring a stereo, more chocolate blocks behind the dash than a cadburys factory...
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>wrightyson</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233225</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233224</link>
                        <pubDate>Mon, 10 Jun 2013 19:29:52 +0000</pubDate>
                        <description><![CDATA[there is probably autoleads harness adapter/converter that will go between car and iso end of the jvc]]></description>
                        <content:encoded><![CDATA[<p>there is probably autoleads harness adapter/converter that will go between car and iso end of the jvc
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>verticalclimber</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233224</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233223</link>
                        <pubDate>Mon, 10 Jun 2013 18:47:13 +0000</pubDate>
                        <description><![CDATA[I agree, looking at the picture of cd... top 8 are speaker wires, these probably won&#039;t change in the new plug.
Bottom 4 will be;
 permanent live (+12v)
switched live (on off with ignition, s...]]></description>
                        <content:encoded><![CDATA[<p>jam bo - Member<br />
then you need to do it the old way, wiring diagram, set of cable strippers and a roll of insulating tape...</p>
<p>I agree, looking at the picture of cd... top 8 are speaker wires, these probably won't change in the new plug.<br />
Bottom 4 will be;<br />
 permanent live (+12v)<br />
switched live (on off with ignition, saves radio setting ect)<br />
Ground (earth) CD will work with only these 3 wired up<br />
Last one is possibly some light dimmer thing, or electric aerial supply, depending on cd.<br />
Easiest way of finding out is to plug wiring harness in without cd connected, using a multi-meter test each of the 4 lower wires to work out which is which.
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>muddodger</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233223</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233222</link>
                        <pubDate>Mon, 10 Jun 2013 17:19:46 +0000</pubDate>
                        <description><![CDATA[The lead which plugs into the back of the JVC will then have an ISO block ferther down.
will be a case of unplugging the sendei and plugging the JVC in
Happy Days]]></description>
                        <content:encoded><![CDATA[<p>The lead which plugs into the back of the JVC will then have an ISO block ferther down.</p>
<p>will be a case of unplugging the sendei and plugging the JVC in</p>
<p>Happy Days
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>tortoisenothair</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233222</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233221</link>
                        <pubDate>Mon, 10 Jun 2013 12:55:13 +0000</pubDate>
                        <description><![CDATA[Looks like this is what I need :)]]></description>
                        <content:encoded><![CDATA[<p>Looks like this is what I need :)</p>
<p>http://www.ebay.co.uk/itm/JVC-16-PIN-ISO-LEAD-POWER-WIRING-HARNESS-CORD-CABLE-NEW-/260698722781?pt=UK_In_Car_Technology&amp;hash=item3cb2dad1dd
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>Duane...</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233221</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233220</link>
                        <pubDate>Mon, 10 Jun 2013 12:48:28 +0000</pubDate>
                        <description><![CDATA[I&#039;ve just found a picture of the back of the Sendai 688;
[imgThat&#039;s definitely not the same connector as shown in the above manual, looks like an ISO connector to me. Which means, it should ...]]></description>
                        <content:encoded><![CDATA[<p>I've just found a picture of the back of the Sendai 688;</p>
<p>http://www.hillsmotorparts.co.uk/ebay_images/large/571904.jpg</p>
<p>That's definitely not the same connector as shown in the above manual, looks like an ISO connector to me. Which means, it should fit the JVC. Except, the picture that the JVC guy sent me, it definitely wouldn't fit. The JVC looks like it needs one of these 20 pin connectors;</p>
<p>http://static2.tme.eu/katalog_pics/5/d/5/5d5ea9ad34c17091770103ffa7c1be48/zrs-129.jpg
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233220</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233219</link>
                        <pubDate>Mon, 10 Jun 2013 12:27:21 +0000</pubDate>
                        <description><![CDATA[then you need to do it the old way, wiring diagram, set of cable strippers and a roll of insulating tape...]]></description>
                        <content:encoded><![CDATA[<p>then you need to do it the old way, wiring diagram, set of cable strippers and a roll of insulating tape...
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>jam-bo</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233219</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233218</link>
                        <pubDate>Mon, 10 Jun 2013 12:26:06 +0000</pubDate>
                        <description><![CDATA[Yeah, going into Halfords is what I&#039;m thinking of doing, but I wanted to check what adapter I&#039;d need first, as some of the prices of adapters on their site (£30+) would make the excercise a ...]]></description>
                        <content:encoded><![CDATA[<p>Yeah, going into Halfords is what I'm thinking of doing, but I wanted to check what adapter I'd need first, as some of the prices of adapters on their site (£30+) would make the excercise a bit silly (seeing as I'm getting the stereo for £20)..
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233218</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233217</link>
                        <pubDate>Mon, 10 Jun 2013 12:23:06 +0000</pubDate>
                        <description><![CDATA[if it was me - for minimal fuss id just get an iso to go into the back of the JVC and chop it to make it fit whats in the dash already.
failing that i would just go into halfords with the s...]]></description>
                        <content:encoded><![CDATA[<p>if it was me - for minimal fuss id just get an iso to go into the back of the JVC and chop it to make it fit whats in the dash already. </p>
<p>failing that i would just go into halfords with the stereo and the current plug and get one to fit between them</p>
<p>ordering it online is going to lead to alot of tears and wasted time/money
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>trail_rat</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233217</guid>
                    </item>
				                    <item>
                        <title>Confused about car stereo connections..</title>
                        <link>https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233216</link>
                        <pubDate>Mon, 10 Jun 2013 12:20:44 +0000</pubDate>
                        <description><![CDATA[Hi all,
Want to replace the Sendai 688 I currently have, with a JVC R KD303 I&#039;ve found cheap online.
According to the manuals, the Sendai is 20 pin;And the JVC is ISOThe cable diagram for th...]]></description>
                        <content:encoded><![CDATA[<p>Hi all,</p>
<p>Want to replace the Sendai 688 I currently have, with a JVC R KD303 I've found cheap online.</p>
<p>According to the manuals, the Sendai is 20 pin;<br />
http://www.halfords.com/wcsstore/libraries/document/CD688.pdf</p>
<p>And the JVC is ISO<br />
http://www.caraudiocentre.co.uk/product_m-jvc-kd-r303_p-23778.htm</p>
<p>The cable diagram for the Sendai shows an adapter from ISO to 20pin, but I'm pretty sure when I opened mine up there wasn't an adapter, just a bunch of wires taped together (assuming that was instead of the proper connector).</p>
<p>I'm assuming I will need to get an adapter then, to run the JVC stereo with my current wiring? I've searched around but can't find anything suitable..</p>
<p>Ta, Duane.
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/confused-about-car-stereo-connections/#post-5233216</guid>
                    </item>
							        </channel>
        </rss>
