<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									can i bump start a car even if i cant get the ignition light to come on - Chat Forum				            </title>
            <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sun, 05 Apr 2026 02:32:35 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: can i bump start a car even if i cant get the ignition light to come on</title>
                        <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397045</link>
                        <pubDate>Tue, 17 Mar 2009 20:49:33 +0000</pubDate>
                        <description><![CDATA[You thought very wrong :D We had a dicky battery on an old diesel, we used to use the 2m steep drivespace behind teh car to bump it in reverse each morning to save stressing the battery lol....]]></description>
                        <content:encoded><![CDATA[<p>coffeeking, since when has it been possible to bump start any diesel? I thought they were unbumpable...<br />
</p>
<p>You thought very wrong :D We had a dicky battery on an old diesel, we used to use the 2m steep drivespace behind teh car to bump it in reverse each morning to save stressing the battery lol. </p>
<p>If any car was going to be bumpable it would be a D, as it is compression ignition - all you need is a little fuel in there and sufficient piston speed to compress it before the charge leaks past the rings and it'll go bang :) More modern D's require the electrics to be running and the high pressure pump to be turning so they're a bit more picky, but still possible with a run up.
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>coffeeking</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397045</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397044</link>
                        <pubDate>Tue, 17 Mar 2009 20:32:41 +0000</pubDate>
                        <description><![CDATA[lupo is now going thansk to some borrowed jump leads
thanks]]></description>
                        <content:encoded><![CDATA[<p>lupo is now going thansk to some borrowed jump leads</p>
<p>thanks
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>stonemonkey</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397044</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397043</link>
                        <pubDate>Tue, 17 Mar 2009 10:33:23 +0000</pubDate>
                        <description><![CDATA[I have bumped my diesel even with veggie oil in the tank, and even without enough power to light the glow plugs.  It took a few goes though and we had to tow it up the hill of which I live a...]]></description>
                        <content:encoded><![CDATA[<p>coffeeking, since when has it been possible to bump start any diesel? I thought they were unbumpable...</p>
<p>I have bumped my diesel even with veggie oil in the tank, and even without enough power to light the glow plugs.  It took a few goes though and we had to tow it up the hill of which I live at the bottom a few times.  Pain in the arse, and it only worked once, didn't work another time we tried it.</p>
<p>I've also bumped a small petrol car (old skool one tho sans electronics) on a very small hill.  The battery was flat enough not to click when I turned it on, but still got it started.
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>molgrips</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397043</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397042</link>
                        <pubDate>Tue, 17 Mar 2009 09:13:22 +0000</pubDate>
                        <description><![CDATA[Wait for your MOT emissions test before being so confident grasshopper.
edit: read things properly before replying samuri]]></description>
                        <content:encoded><![CDATA[<p>Wait for your MOT emissions test before being so confident grasshopper.</p>
<p>edit: read things properly before replying samuri
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>samuri</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397042</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397041</link>
                        <pubDate>Tue, 17 Mar 2009 09:08:38 +0000</pubDate>
                        <description><![CDATA[Bump started my transit a couple of weeks back and it&#039;s been fine...]]></description>
                        <content:encoded><![CDATA[<p>coffeeking, since when has it been possible to bump start any diesel? I thought they were unbumpable... </p>
<p>Bump started my transit a couple of weeks back and it's been fine...
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>Sam</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397041</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397040</link>
                        <pubDate>Tue, 17 Mar 2009 09:01:25 +0000</pubDate>
                        <description><![CDATA[Petrol NO chance .. need power to generate a  spark etc  and in order for the alternator to charge the engine must be running but in order for the spark the alternator must be working .. bes...]]></description>
                        <content:encoded><![CDATA[<p>Petrol NO chance .. need power to generate a  spark etc  and in order for the alternator to charge the engine must be running but in order for the spark the alternator must be working .. best case it will start and stall very quickly thereafter.<br />
Diesel will bump depending on how the fuel is controlled(mechanical pump and no elctric solenoid) you can actually do this without a battery attached if you want!!!! the compression of Diesel is what ignites it and it does not require a spark or electrical power ... the fact the diesel engine is cold though means you are unlikely to start it in the real world but you would on a very big hill.
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>Junkyard</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397040</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397039</link>
                        <pubDate>Tue, 17 Mar 2009 08:47:39 +0000</pubDate>
                        <description><![CDATA[coffeeking, since when has it been possible to bump start any diesel? I thought they were unbumpable...]]></description>
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>sq225917</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397039</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397038</link>
                        <pubDate>Tue, 17 Mar 2009 08:08:46 +0000</pubDate>
                        <description><![CDATA[Just get the jump leads!  But,  - make sure to disconnect the jump leads before you do this.]]></description>
                        <content:encoded><![CDATA[<p>Just get the jump leads!  But, Get yourself some jump leads and a spare car, watch out for the leads melting and fire the slave car up as soon as poss, and take it for a good run - make sure to disconnect the jump leads before you do this.
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>deadlydarcy</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397038</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397037</link>
                        <pubDate>Tue, 17 Mar 2009 06:53:12 +0000</pubDate>
                        <description><![CDATA[Don&#039;t try and bump start it if it has a catalytic converter!
Bump starting will/may introduce petrol into the exhast system
with is very bad for the cat, or at least that is what they told m...]]></description>
                        <content:encoded><![CDATA[<p>Don't try and bump start it if it has a catalytic converter!<br />
Bump starting will/may introduce petrol into the exhast system<br />
with is very bad for the cat, or at least that is what they told me.
						                            <category domain="https://singletrackworld.com/forum/off-topic/">Chat Forum</category>                        <dc:creator>grahamh</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397037</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397036</link>
                        <pubDate>Tue, 17 Mar 2009 00:48:43 +0000</pubDate>
                        <description><![CDATA[ok thanks everyone i also live at the top of a big hill and reckon i could get the car upto 25 mph but i might buy some decent leads tomorrow to be on the safe side]]></description>
                        <content:encoded><![CDATA[<p>ok thanks everyone i also live at the top of a big hill and reckon i could get the car upto 25 mph but i might buy some decent leads tomorrow to be on the safe side
                        <guid isPermaLink="true">https://singletrackworld.com/forum/off-topic/can-i-bump-start-a-car-even-if-i-cant-get-the-ignition-light-to-come-on/#post-397036</guid>
                    </item>
							        </channel>
        </rss>
