Singletrack's forums are sponsored by...
Forum sponsored by Saracen
Bassists of Singlet...
Bassists of Singletrackworld....
62 Users
133 Reactions
Listen to Blitzkrieg Bop and play different notes on the E string until you realise (by ear) that you're playing the same note as the bass. Y
ill try that when next at home.  i genuinely think ive got a poor ear for things like that tho and doubt very much ill suss out which note he starts from but ill give it a go🙂
I think you will surprise yourself. You only need to identify that first note.
just got a few minutes to myself at home so gave it a try.  im hearing the 5th fret on E string, so open A.   with the other notes the 5th and 7th on A string (so E and F#?).  is that right?
...... chord stuff.  too complex for my little brain at the mo, ill investigate further when im a bit further into my journey.
Posted : 17/02/2025 5:18 pm
5th and 7th on A would be D and E
I'd see that as a 1-4-5 progression, being 1st, 4th and 5th notes of the scale (whereas chord is 1-3-5) and 145 is very commonly used. This is where even if you don't know theory, patterns repeat over and over, just change rhythm and you'll recognise a new bass line.
Eg, Rainy Night in Soho; single long notes 145 starting on I think C, and then as song develops it goes to 1-5-1 and then run up the scale to 4/F
Posted : 17/02/2025 6:36 pm
Posted by: sadexpunk
Nearly. As theotherjohnv says, it's A D E . But your ear clearly does work despite your misgivings!
Good plan. Others have said concentrate on plucking and fretting cleanly on even repeated notes for the time being. We'll have you playing Hysteria in a couple of weeks... 😉
Posted : 17/02/2025 6:50 pm
durrr, of course it is, i read the chart wrong, went 7th and 9th.  but was i right with the blitzkrieg notes?
nope, not a scooby.  give me a few months 🙂
thanks
Posted : 17/02/2025 6:56 pm
Yep, you were spot on.
Posted : 17/02/2025 10:12 pm
Page 14 / 14
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
