<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									stans yellow tape and roam 50 wheel, leaking air help - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sun, 05 Apr 2026 01:53:16 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: stans yellow tape and roam 50 wheel, leaking air help</title>
                        <link>https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999936</link>
                        <pubDate>Wed, 15 Apr 2015 10:22:42 +0000</pubDate>
                        <description><![CDATA[Just get some Stans in there and pump them up . You don&#039;t need to use an inner tube to seat the tape as the air pressure will do that perfectly well.Tyre might go down a bit before you take ...]]></description>
                        <content:encoded><![CDATA[<p>Just get some Stans in there and pump them up . You don't need to use an inner tube to seat the tape as the air pressure will do that perfectly well.Tyre might go down a bit before you take it for a ride but it should be fine after that.
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>RamseyNeil</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999936</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999935</link>
                        <pubDate>Wed, 15 Apr 2015 10:16:39 +0000</pubDate>
                        <description><![CDATA[I use a tube to inflate the tyre when I first fit new rim tape. I guess it physically presses the tape onto the rim and helps it seal.
So, fit a tube and pump it up hard. Give it an hour or ...]]></description>
                        <content:encoded><![CDATA[<p>I use a tube to inflate the tyre when I first fit new rim tape. I guess it physically presses the tape onto the rim and helps it seal.</p>
<p>So, fit a tube and pump it up hard. Give it an hour or so, remove the tube and off you go tubeless.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>rugbydick</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999935</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999934</link>
                        <pubDate>Wed, 15 Apr 2015 09:18:32 +0000</pubDate>
                        <description><![CDATA[the rims are asymmetric if that makes a difference?]]></description>
                        <content:encoded><![CDATA[<p>the rims are asymmetric if that makes a difference?
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>jsm</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999934</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999933</link>
                        <pubDate>Wed, 15 Apr 2015 08:48:20 +0000</pubDate>
                        <description><![CDATA[I had, maybe incorrectly, assumed that the stans tape would be longer lasting?]]></description>
                        <content:encoded><![CDATA[<p>I had, maybe incorrectly, assumed that the stans tape would be longer lasting?
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999933</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999932</link>
                        <pubDate>Wed, 15 Apr 2015 08:44:23 +0000</pubDate>
                        <description><![CDATA[3.) remove stans tape and just use gorilla tape anyway!
I have set up many sets of wheels using just this!]]></description>
                        <content:encoded><![CDATA[<p>3.) remove stans tape and just use gorilla tape anyway!</p>
<p>I have set up many sets of wheels using just this!
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>lerk</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999932</guid>
                    </item>
				                    <item>
                        <title>stans yellow tape and roam 50 wheel, leaking air help</title>
                        <link>https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999931</link>
                        <pubDate>Wed, 15 Apr 2015 08:41:44 +0000</pubDate>
                        <description><![CDATA[I managed to rip the sram tubeless rim tape when I punctured a wheel. Last night I removed it and put on some yellow stans tape. I pumped it up to 40psi and left it over night to bed the tap...]]></description>
                        <content:encoded><![CDATA[<p>I managed to rip the sram tubeless rim tape when I punctured a wheel. Last night I removed it and put on some yellow stans tape. I pumped it up to 40psi and left it over night to bed the tape in with no stans fluid. it had gone down a bit this morning so I pumped it up again. I can hear some air leaking out from one of the nipples. The tape looks well seated in the rim now, but there's definitely air coming out slowly.</p>
<p>Do I<br />
1. just add stans fluid and hope it will seal?<br />
2. remove the tape and seal under the tape with gorilla tape? I'm worried that will add too much volume by having two tapes.</p>
<p>any thoughts?
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/stans-yellow-tape-and-roam-50-wheel-leaking-air-help/#post-6999931</guid>
                    </item>
							        </channel>
        </rss>
