<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Square taper 1x10 set up? - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sun, 05 Apr 2026 02:07:56 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: Square taper 1x10 set up?</title>
                        <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632362</link>
                        <pubDate>Fri, 14 Nov 2014 10:27:54 +0000</pubDate>
                        <description><![CDATA[+1 for Deore cranks
i&#039;ve also got a pair of them for sale. theyre in good condition, all the threads are good and visually there are a few age related scuffs
also have a square taper b/b (sh...]]></description>
                        <content:encoded><![CDATA[<p>+1 for Deore cranks</p>
<p>i've also got a pair of them for sale. theyre in good condition, all the threads are good and visually there are a few age related scuffs<br />
also have a square taper b/b (shimano UN-53 for a 68mm shell with a 113mm axle width)in good condition and still spins smoothly<br />
£15 + postage for both of them<br />
http://i919.photobucket.com/albums/ad37/gonzy1/20140308_102050_zps0f93d30a.jpg<br />
http://i919.photobucket.com/albums/ad37/gonzy1/20140308_102059_zpsa66847e8.jpg<br />
http://i919.photobucket.com/albums/ad37/gonzy1/20140308_100118_zps520b29b8.jpg
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>gonzy</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632362</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632361</link>
                        <pubDate>Fri, 14 Nov 2014 10:02:24 +0000</pubDate>
                        <description><![CDATA[Defo NW ring, mounted where the middle ring of a triple would go.
Old cranks can polish up nicely with some wet &amp; dry &amp; metal polish]]></description>
                        <content:encoded><![CDATA[<p>Defo NW ring, mounted where the middle ring of a triple would go.</p>
<p>Old cranks can polish up nicely with some wet &amp; dry &amp; metal polish
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>richardthird</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632361</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632360</link>
                        <pubDate>Fri, 14 Nov 2014 09:43:08 +0000</pubDate>
                        <description><![CDATA[A single ring should last longer than a double/triple setup as theres no shifting going on.  for the price id not worry about wear]]></description>
                        <content:encoded><![CDATA[<p>A single ring should last longer than a double/triple setup as theres no shifting going on.  for the price id not worry about wear
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>bland</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632360</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632359</link>
                        <pubDate>Fri, 14 Nov 2014 09:21:12 +0000</pubDate>
                        <description><![CDATA[Pics sent. 175mm length.
The surly ring is very good and much lighter than the on-one stainless. You will need a chain guide for all these though. You need to balance up the cost of a stainl...]]></description>
                        <content:encoded><![CDATA[<p>Pics sent. 175mm length.</p>
<p>The surly ring is very good and much lighter than the on-one stainless. You will need a chain guide for all these though. You need to balance up the cost of a stainless and guide, and the associated long life of this v a thick/thin ring that won't last as long.</p>
<p>Edit - all the stainless rings will need thinner crank bolts to fit. Some of the thick/thin rings like the on-one ring are so fat that standard bolts fit.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>Yak</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632359</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632358</link>
                        <pubDate>Fri, 14 Nov 2014 08:28:04 +0000</pubDate>
                        <description><![CDATA[Stainless rings will require some kind of guide to keep the chain. Narrow/wide, XX1-style chainrings (like the Superstar I/O mentioned above) won&#039;t.  If you are using a guide then that adds ...]]></description>
                        <content:encoded><![CDATA[<p>Stainless rings will require some kind of guide to keep the chain. Narrow/wide, XX1-style chainrings (like the Superstar I/O mentioned above) won't.  If you are using a guide then that adds an extra issue of possibly having to use an e-type square-taper bottom-bracket, which are harder to come by nowadays.  There are seattube mounted guides too though, but it's still another, admittedly one-time, cost on top of everything else.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>warpcow</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632358</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632357</link>
                        <pubDate>Fri, 14 Nov 2014 03:44:43 +0000</pubDate>
                        <description><![CDATA[Thanks guys, that&#039;s just what I was hoping to hear :)
The On One stainless ring looks ideal. Do they need special bolts/washers to work with Deores like the Truvativ squares?
Yak, I&#039;m quite ...]]></description>
                        <content:encoded><![CDATA[<p>Thanks guys, that's just what I was hoping to hear :)</p>
<p>The On One stainless ring looks ideal. Do they need special bolts/washers to work with Deores like the Truvativ squares?</p>
<p>Yak, I'm quite interested in the taper Deores, could you send an email to anotherguinnesspls@gmail.com, some photos would be great. What length are they?</p>
<p>What other stainless rings are good quality, reliable, and fairly priced out there? How do people get on with Surly stainless single up front?</p>
<p>Many thanks
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>The_End</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632357</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632356</link>
                        <pubDate>Thu, 13 Nov 2014 21:42:21 +0000</pubDate>
                        <description><![CDATA[Can&#039;t comment on cheap cranks but I&#039;ve been very impressed by the superstar N/W chainring.]]></description>
                        <content:encoded><![CDATA[<p>Can't comment on cheap cranks but I've been very impressed by the superstar N/W chainring.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>davewalsh</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632356</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632355</link>
                        <pubDate>Thu, 13 Nov 2014 21:09:24 +0000</pubDate>
                        <description><![CDATA[Got some deore sq taper cranks. £10 + postage?
I would then pair them with an on-one thick-thin or even cheaper - the stainless chain-ring. Would need a chain guide then.]]></description>
                        <content:encoded><![CDATA[<p>Got some deore sq taper cranks. £10 + postage?</p>
<p>I would then pair them with an on-one thick-thin or even cheaper - the stainless chain-ring. Would need a chain guide then.
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632355</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632354</link>
                        <pubDate>Thu, 13 Nov 2014 20:52:55 +0000</pubDate>
                        <description><![CDATA[Wtd ad on here might sort you out]]></description>
                        <content:encoded><![CDATA[<p>Wtd ad on here might sort you out
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>cyclistm</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632354</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632353</link>
                        <pubDate>Thu, 13 Nov 2014 20:51:50 +0000</pubDate>
                        <description><![CDATA[Deore square taper cranks with superstar io chainring for me]]></description>
                        <content:encoded><![CDATA[<p>Deore square taper cranks with superstar io chainring for me
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/square-taper-1x10-set-up/#post-6632353</guid>
                    </item>
							        </channel>
        </rss>
