<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									SLX rear mech clutch - is it borked? - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sun, 05 Apr 2026 01:44:29 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: SLX rear mech clutch - is it borked?</title>
                        <link>https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12595467</link>
                        <pubDate>Thu, 27 Oct 2022 22:50:50 +0000</pubDate>
                        <description><![CDATA[&#x1f44d;]]></description>
                        <content:encoded><![CDATA[&#x1f44d;]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>neilthewheel</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12595467</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12595364</link>
                        <pubDate>Thu, 27 Oct 2022 21:35:14 +0000</pubDate>
                        <description><![CDATA[Yes it&#039;s repairable. I repaired mine with a lever from SJS.
There&#039;s a tiny metal clip which holds the lever in place (a few mils wide), don&#039;t lose it!
A tiny smear of driveshaft moly greas...]]></description>
                        <content:encoded><![CDATA[Yes it's repairable. I repaired mine with a lever from SJS.
There's a tiny metal clip which holds the lever in place (a few mils wide), don't lose it!
A tiny smear of driveshaft moly grease on the clutch barrel and grease the housing seal to help stop water getting in. If the adjustment band bolt has been undoing itself (the clutch loses resistance over time) put a tiny bit of blue Loctite on it's thread.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>chestercopperpot</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12595364</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12595119</link>
                        <pubDate>Thu, 27 Oct 2022 17:52:04 +0000</pubDate>
                        <description><![CDATA[Thanks for the tips!]]></description>
                        <content:encoded><![CDATA[Thanks for the tips!]]></content:encoded>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12595119</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12595060</link>
                        <pubDate>Thu, 27 Oct 2022 16:55:56 +0000</pubDate>
                        <description><![CDATA[If you can get a replacement lever, the clutch mechanism is easy to disassemble and adjust so I reckon you&#039;ll be able to bring it back to life. Just be careful where you put grease. There&#039;s ...]]></description>
                        <content:encoded><![CDATA[If you can get a replacement lever, the clutch mechanism is easy to disassemble and adjust so I reckon you'll be able to bring it back to life. Just be careful where you put grease. There's a Park Tool video that goes into quite a lot of detail: https://youtu.be/8TqdoAAn-go]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>rhayter</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12595060</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12594945</link>
                        <pubDate>Thu, 27 Oct 2022 15:40:44 +0000</pubDate>
                        <description><![CDATA[You can adjust it to your preference once you&#039;ve taken the cap off. Just wind the bolt out a little to reduce the friction.]]></description>
                        <content:encoded><![CDATA[You can adjust it to your preference once you've taken the cap off. Just wind the bolt out a little to reduce the friction.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>davros</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12594945</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12594928</link>
                        <pubDate>Thu, 27 Oct 2022 15:30:32 +0000</pubDate>
                        <description><![CDATA[SJS have the lever in stock but no clutch assembly until June ‘23 &#x1f62e;
Might give it a go anyway.
I hate these clutches, they upset the shifting and create a lot of drag.]]></description>
                        <content:encoded><![CDATA[SJS have the lever in stock but no clutch assembly until June ‘23 &#x1f62e;
I hate these clutches, they upset the shifting and create a lot of drag.]]></content:encoded>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12594928</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12590987</link>
                        <pubDate>Mon, 24 Oct 2022 17:38:32 +0000</pubDate>
                        <description><![CDATA[You can try and buy a new lever part... I ended up transfering one from a borked Deore mech ... might be worth buying a new actual clutch as well whilst you have it in bits]]></description>
                        <content:encoded><![CDATA[You can try and buy a new lever part... I ended up transfering one from a borked Deore mech ... might be worth buying a new actual clutch as well whilst you have it in bits]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>stevextc</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12590987</guid>
                    </item>
				                    <item>
                        <title>SLX rear mech clutch - is it borked?</title>
                        <link>https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12590953</link>
                        <pubDate>Mon, 24 Oct 2022 17:19:46 +0000</pubDate>
                        <description><![CDATA[I went to release the mech clutch and lo and behold, the on/off lever is gone, apparently snapped off. Is this fixable?
It&#039;s an M7000 11 speed.
TIA.]]></description>
                        <content:encoded><![CDATA[I went to release the mech clutch and lo and behold, the on/off lever is gone, apparently snapped off. Is this fixable?
It's an M7000 11 speed.
TIA.]]></content:encoded>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/slx-rear-mech-clutch-is-it-borked/#post-12590953</guid>
                    </item>
							        </channel>
        </rss>
