<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Shimano brake mounting - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sat, 04 Apr 2026 20:31:36 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: Shimano brake mounting</title>
                        <link>https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/#post-5923394</link>
                        <pubDate>Wed, 05 Feb 2014 19:43:19 +0000</pubDate>
                        <description><![CDATA[OK, he now has a bigger issue.  He&#039;s needing brake because his Sram XX are garbage. unfortunately he has a direct mount X-loc fork lever mounted to his XX brake levers.
Can you get a clamp...]]></description>
                        <content:encoded><![CDATA[<p>OK, he now has a bigger issue.  He's needing brake because his Sram XX are garbage. unfortunately he has a direct mount X-loc fork lever mounted to his XX brake levers.  </p>
<p>Can you get a clamp to convert the matchmaker for the X-loc to normal handlebar clamp?
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>Blazin-saddles</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/#post-5923394</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/#post-5923393</link>
                        <pubDate>Wed, 05 Feb 2014 19:37:27 +0000</pubDate>
                        <description><![CDATA[the SLX i&#039;m seeing also seem to have a Bite Point Adj?  Hence my question really, no point in paying for anymore than required!
I think the rear adapter i&#039;d need for him is a SMMA90R140PS co...]]></description>
                        <content:encoded><![CDATA[<p>the SLX i'm seeing also seem to have a Bite Point Adj?  Hence my question really, no point in paying for anymore than required!</p>
<p>I think the rear adapter i'd need for him is a SMMA90R140PS correct?
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/#post-5923393</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/#post-5923392</link>
                        <pubDate>Wed, 05 Feb 2014 19:32:34 +0000</pubDate>
                        <description><![CDATA[Xt have bit point adjustment, look a little nicer and cost more]]></description>
                        <content:encoded><![CDATA[<p>Xt have bit point adjustment, look a little nicer and cost more
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>dvatcmark</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/#post-5923392</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/#post-5923391</link>
                        <pubDate>Wed, 05 Feb 2014 19:32:00 +0000</pubDate>
                        <description><![CDATA[The new brake will come with a 160mm is adapter so you&#039;ll either need a new 160 rotor or new 140 mm is to pm adapter to use the existing rotor.]]></description>
                        <content:encoded><![CDATA[<p>The new brake will come with a 160mm is adapter so you'll either need a new 160 rotor or new 140 mm is to pm adapter to use the existing rotor.
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/#post-5923391</guid>
                    </item>
				                    <item>
                        <title>Shimano brake mounting</title>
                        <link>https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/#post-5923390</link>
                        <pubDate>Wed, 05 Feb 2014 19:28:00 +0000</pubDate>
                        <description><![CDATA[Hi Guys,
Need a quick bit of help to help a mate get some new brakes.  Never dealt with Shimano as I&#039;m a Hope guy and unsure of the fitting protocol.
He has a Fisher Superfly with IS mounts ...]]></description>
                        <content:encoded><![CDATA[<p>Hi Guys,</p>
<p>Need a quick bit of help to help a mate get some new brakes.  Never dealt with Shimano as I'm a Hope guy and unsure of the fitting protocol.</p>
<p>He has a Fisher Superfly with IS mounts rather than post mount. he uses 140mm rear rotors normally as he has XX ones already.</p>
<p>Will the Shimano brakes on Melincycles work with a 140mm rear rotor or will he need to buy new rear rotors and adapters?  Are XX rotors compatible with Shimano brakes?</p>
<p>What's the difference between SLX and XT brakes?</p>
<p>Cheers for a hopefully speedy answer. Thanks.
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/shimano-brake-mounting/#post-5923390</guid>
                    </item>
							        </channel>
        </rss>
