Replacement sram co...
[Closed] Replacement sram code rsc brake hose
5 Users
I can’t seem to see any or if it’s a specific bit of kit I need, Or does any one know of any alternative I can use?
Is it as simple as undoing it at the caliper end and then re bleeding?
Posted : 05/01/2022 8:14 pm
Yes, it’s that simple. Everything you need to shorten comes in the new hose kit, bar the cutting tool.
Posted : 05/01/2022 8:36 pm
Eek is it that 35 quid kit? Is that the only option?
Posted : 05/01/2022 8:47 pm
Infact I can’t even find the kit in stock anywhere online can anyone help out or know of a place I can buy one please?
Posted : 05/01/2022 8:49 pm
IIRC (worth checking) it’s the same hose as the Level caliper - might be some of those?
Posted : 05/01/2022 9:04 pm
Thanks will check it out hopefully some one will have some somewhere
Posted : 05/01/2022 9:12 pm
I don’t think it’s the same hose as the Level btw.
Posted : 05/01/2022 9:19 pm
Bugger this is going to be a problem doesn’t seem to be any online anywhere 🤦‍♂️🤦‍♂️
Posted : 05/01/2022 9:29 pm
Just checked Zyro and back in stock at the end of the month dude.
Out of interest, you need to replace the front or reaR?
Posted : 05/01/2022 9:32 pm
Howdy pete thanks for checking for me
Rear long one needed, I wonder if anyone has stock anywhere 🤣
I might end up having to buy a whole new rear brake at this rate 😌
Posted : 05/01/2022 9:56 pm
Managed to get one from Germany! God bless there stupidly efficient country!
Probably cheaper delivered too than I can get in the uk even after brexit 🤣
Posted : 05/01/2022 10:21 pm
No difference in buying the kit as it’s only available as 1850mm length which you cut down to fit front or rear.
Posted : 06/01/2022 7:52 am
I was about to chip in last night and say Germany, that's where Ash ended up getting one from for a princly sum!
Posted : 06/01/2022 8:41 am
