<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Need to cut steel steerer - can I use a pipe cutter? - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sat, 04 Apr 2026 20:32:54 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: Need to cut steel steerer - can I use a pipe cutter?</title>
                        <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442730</link>
                        <pubDate>Thu, 02 Apr 2009 08:13:22 +0000</pubDate>
                        <description><![CDATA[in the absence of a vice, a saw, and the experience of using both a pipe-cutter isn&#039;t a bad way of doing it IMO. just do it slowly. as stated above you will need to clean the cut up, but it ...]]></description>
                        <content:encoded><![CDATA[<p>in the absence of a vice, a saw, and the experience of using both a pipe-cutter isn't a bad way of doing it IMO. just do it slowly. as stated above you will need to clean the cut up, but it will be a straight cut at least.
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>Del</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442730</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442729</link>
                        <pubDate>Thu, 02 Apr 2009 08:12:10 +0000</pubDate>
                        <description><![CDATA[pipe cutters are effective for shortening handlebars - just file/ream out the inside after to get end caps in
don&#039;t know about steerer  though- what metal is it?]]></description>
                        <content:encoded><![CDATA[<p>pipe cutters are effective for shortening handlebars - just file/ream out the inside after to get end caps in</p>
<p>don't know about steerer  though- what metal is it?
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>bigeyedbeans</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442729</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442728</link>
                        <pubDate>Thu, 02 Apr 2009 08:09:18 +0000</pubDate>
                        <description><![CDATA[I use a couple of spacers and cut between them. Makes a nice straight cut.]]></description>
                        <content:encoded><![CDATA[<p>I use a couple of spacers and cut between them. Makes a nice straight cut.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>RooleyMoor</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442728</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442727</link>
                        <pubDate>Thu, 02 Apr 2009 08:06:46 +0000</pubDate>
                        <description><![CDATA[use an old stem as a guide.]]></description>
                        <content:encoded><![CDATA[<p>use an old stem as a guide.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>thomthumb</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442727</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442726</link>
                        <pubDate>Thu, 02 Apr 2009 08:05:14 +0000</pubDate>
                        <description><![CDATA[with pipe cutter it tends to burr on the outside so needs a file off to fit stem]]></description>
                        <content:encoded><![CDATA[<p>with pipe cutter it tends to burr on the outside so needs a file off to fit stem
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>firestarter</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442726</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442725</link>
                        <pubDate>Thu, 02 Apr 2009 07:59:36 +0000</pubDate>
                        <description><![CDATA[[url[img]]></description>
                        <content:encoded><![CDATA[<p>http://cgi.ebay.co.uk/X-Tools-Saw-Guide-for-steerer-tubes-bars-seatposts_W0QQitemZ230332953996QQcmdZViewItemQQptZUK_Spots_Leisure_Cycling_Tools_RepairKits?hash=item230332953996&amp;_trksid=p3286.c0.m14&amp;_trkparms=72%3A1688%7C66%3A2%7C65%3A12%7C39%3A2%7C240%3A1318</p>
<p>http://i.ebayimg.com/07/!BN9CQ8gB2k~$(KGrHgoOKk!EjlLmZICkBJsTERJ!J!~~_2.JPG
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>rOcKeTdOg</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442725</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442724</link>
                        <pubDate>Thu, 02 Apr 2009 07:59:17 +0000</pubDate>
                        <description><![CDATA[Hmmm.... Re: Pipe Cutters
If I already have the SFN inserted below the cut-line then internal burrs won&#039;t matter right? The fork is a cheap steel rigid I am putting on a commuter bike for my...]]></description>
                        <content:encoded><![CDATA[<p>Hmmm.... Re: Pipe Cutters</p>
<p>If I already have the SFN inserted below the cut-line then internal burrs won't matter right? The fork is a cheap steel rigid I am putting on a commuter bike for my wife. ...
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>poppa</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442724</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442723</link>
                        <pubDate>Thu, 02 Apr 2009 07:54:11 +0000</pubDate>
                        <description><![CDATA[What is this saw-guide you speak of?]]></description>
                        <content:encoded><![CDATA[<p>What is this saw-guide you speak of?
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442723</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442722</link>
                        <pubDate>Thu, 02 Apr 2009 07:53:42 +0000</pubDate>
                        <description><![CDATA[i did mine other day just make sure you do it up gradually and file any burrs from it]]></description>
                        <content:encoded><![CDATA[<p>i did mine other day just make sure you do it up gradually and file any burrs from it
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442722</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442721</link>
                        <pubDate>Thu, 02 Apr 2009 07:53:38 +0000</pubDate>
                        <description><![CDATA[The problem with using them is that it will crimp the end of the steerer inwards so the internal bore won&#039;t be straight, making it hard to fit the star fangled nut, or perhaps impossible to ...]]></description>
                        <content:encoded><![CDATA[<p>The problem with using them is that it will crimp the end of the steerer inwards so the internal bore won't be straight, making it hard to fit the star fangled nut, or perhaps impossible to fit a Hed Doctor.</p>
<p>Buy the guide tool from CRC and a decent 12" hacksaw, even if you only use it once in a blue moon, you'll feel loads better when you're cutting the steerer on your expensive forks.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>Driller</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/need-to-cut-steel-steerer-can-i-use-a-pipe-cutter/#post-442721</guid>
                    </item>
							        </channel>
        </rss>
