London cycling.
[Closed] London cycling.
"I'm sorry to say the evidence would suggest otherwise. Seceral fixie riders hit the deck in comedy fashion after grabbing a handfull of front. You seriously think you have more control in the ice with a fixie than I do with 2 rim brakes? "
yes because my front brake is the same as yours, it's no different and works the same way.
rear brakes are less effective than fronts and certainly aren't going to be used to stop you only for slowing down.
if you touch the rear brake with the freewheel over a slippery surface it's highly likely that once it starts to slip it will lock and keep slipping, with fixed the wheel cannot lock up (if your legs are still moving) so even if it slips it will regain grip quicker.
much prefer town riding in the winter as it feels a lot safer over manhole covers and in the wet on the fixed.
i wasn't there so can't really comment on your anecdote except if you "grab a handfull of front" on ice you are going down whatever you ride.
Posted : 04/06/2011 10:36 am
Where you are wrong is the fact that you can't keep a constant braking force on the rear wheel throughout the revolution of the crank. When the crank is hoziontal you obvioulsy have much more braking force on the rear than when your cranks are vertical, thus for every revolution of the cranks the braking force is increasing and decreasing. Now, if you think about it, with my rim brake I can apply a constant braking force. Tell me, which one is more effective, I good constnant braking force or a constantly changing braking force?
I'll tell you what, next time it's icy we'll go and ride some frozen 25%'s and see how you get on.
Posted : 12/06/2011 9:43 am
a moot point considering that your brake will lock in an instant and stay locked long enough to end up on your arse no matter how carefully you try and modulate it.
i have no interest in riding with you, it would be like 2 bald men arguing over a comb and about as exciting.
Posted : 12/06/2011 9:57 am
Page 2 / 2
