<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Knackered old 7spd chain with a few new 10spd links, will it work? - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sat, 04 Apr 2026 19:33:33 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: Knackered old 7spd chain with a few new 10spd links, will it work?</title>
                        <link>https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873525</link>
                        <pubDate>Thu, 19 Feb 2015 10:58:56 +0000</pubDate>
                        <description><![CDATA[Singlespeed? Might be OK.
Geared...I&#039;d avoid.]]></description>
                        <content:encoded><![CDATA[<p>Singlespeed? Might be OK.</p>
<p>Geared...I'd avoid.
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>cynic-al</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873525</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873524</link>
                        <pubDate>Thu, 19 Feb 2015 10:37:44 +0000</pubDate>
                        <description><![CDATA[I imagine that if you use 7 speed Powerlinks, you could add in 10 speed links as long as they&#039;re both &quot;inner&quot; links at the two ends.
I suspect it&#039;ll be acceptable as a short term solution on...]]></description>
                        <content:encoded><![CDATA[<p>the 10 speed links, were they powerlinks/similar? In which case how did you get them to link up? 10 speed powerlink's pins being shorter than 6/7/8speed, and so you can't get them through the inner plates of the chain and locked properly.</p>
<p>I imagine that if you use 7 speed Powerlinks, you could add in 10 speed links as long as they're both "inner" links at the two ends.</p>
<p>I suspect it'll be acceptable as a short term solution on a bike that doesn't get much abuse, but I'd not be leaving it like that.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>njee20</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873524</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873523</link>
                        <pubDate>Thu, 19 Feb 2015 10:32:02 +0000</pubDate>
                        <description><![CDATA[No. No no no.
The amount of 10 speed Shimano chains I&#039;ve snapped shortly after bodging them with a pin tool instead of a new pin or a quick link is, well... it&#039;s two. But that&#039;s enough to s...]]></description>
                        <content:encoded><![CDATA[<p>No. No no no. </p>
<p>The amount of 10 speed Shimano chains I've snapped shortly after bodging them with a pin tool instead of a new pin or a quick link is, well... it's two. But that's enough to suggest an unholy mix of knackered 7 speed and much narrower 10 speed is going to result in a knee/stem interface as soon as you start pedalling up the nearest hill.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>finbar</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873523</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873522</link>
                        <pubDate>Thu, 19 Feb 2015 09:21:20 +0000</pubDate>
                        <description><![CDATA[the 10 speed links, were they powerlinks/similar? In which case how did you get them to link up? 10 speed powerlink&#039;s pins being shorter than 6/7/8speed, and so you can&#039;t get them through th...]]></description>
                        <content:encoded><![CDATA[<p>the 10 speed links, were they powerlinks/similar? In which case how did you get them to link up? 10 speed powerlink's pins being shorter than 6/7/8speed, and so you can't get them through the inner plates of the chain and locked properly. </p>
<p>Otherwise, iirc the space between the inner plates on a 10 speed chain is also narrower so if you used a few bits of 10speed to lengthen the chain, you might find that the 10speed bit jumps on the smaller sprockets under heavy load as it doesn't sit all the way into the teeth as well. </p>
<p>Finally i don't have great experience of rejoining 'geared' chains  for derailleur systems (ie ones that aren't bmx chains with massive outer plates and wide pins) without using proper joining pins or quicklinks/powerlinks; they tend to fail after a while at the point you pushed the pin back into the outer plate. Fine to get you home if you break a chain, but will break again later on at most inconvenient moment.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>julianwilson</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873522</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873521</link>
                        <pubDate>Thu, 19 Feb 2015 09:21:09 +0000</pubDate>
                        <description><![CDATA[It&#039;s an ancient Marin with 7spd.]]></description>
                        <content:encoded><![CDATA[<p>It's an ancient Marin with 7spd.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>qwerty</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873521</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873520</link>
                        <pubDate>Thu, 19 Feb 2015 09:13:22 +0000</pubDate>
                        <description><![CDATA[What drivetrain is it on? 7/10 speed? Singlespeed?]]></description>
                        <content:encoded><![CDATA[<p>What drivetrain is it on? 7/10 speed? Singlespeed?
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>everyone</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873520</guid>
                    </item>
				                    <item>
                        <title>Knackered old 7spd chain with a few new 10spd links, will it work?</title>
                        <link>https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873519</link>
                        <pubDate>Thu, 19 Feb 2015 09:07:06 +0000</pubDate>
                        <description><![CDATA[So, last nights beer, pizza and bike fettle resulted in this unlikely combo.
It passed the cycle stand spin the drivechain test.
But, will it work going up a hill with load applied?
It was &quot;...]]></description>
                        <content:encoded><![CDATA[<p>So, last nights beer, pizza and bike fettle resulted in this unlikely combo.</p>
<p>It passed the cycle stand spin the drivechain test.</p>
<p>But, will it work going up a hill with load applied?</p>
<p>It was "fixed" under duress, and my work was not guaranteed. Apparently the spare 7spd links were left on a window sill somewhere.</p>
<p>Shonkyness sprungs to mind!
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/knackered-old-7spd-chain-with-a-few-new-10spd-links-will-it-work/#post-6873519</guid>
                    </item>
							        </channel>
        </rss>
