<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									How to remove a pedal stuck in a carbon crank - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sun, 05 Apr 2026 01:00:45 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: How to remove a pedal stuck in a carbon crank</title>
                        <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972827</link>
                        <pubDate>Fri, 23 Jul 2021 20:39:09 +0000</pubDate>
                        <description><![CDATA[I&#039;d beware about putting considerable strain on it as the thread will be glued into the carbon arm and too much force could rip the threaded part right out.
Possibly look more to finding som...]]></description>
                        <content:encoded><![CDATA[I'd beware about putting considerable strain on it as the thread will be glued into the carbon arm and too much force could rip the threaded part right out.
Possibly look more to finding something that will leech into the threads providing a lube, maybe diesel or some quality penetrating fluid, or even drill out the pedal stub after sawing it off]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>dyna-ti</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972827</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972781</link>
                        <pubDate>Fri, 23 Jul 2021 19:45:40 +0000</pubDate>
                        <description><![CDATA[I&#039;ve never had to torque my pedals that high. I do them hand tight and a nip.
When I have had a stuck pedal I stick the crank on the ground and stand on the Allen key / breaker.]]></description>
                        <content:encoded><![CDATA[I've never had to torque my pedals that high. I do them hand tight and a nip.
When I have had a stuck pedal I stick the crank on the ground and stand on the Allen key / breaker.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>jamiemcf</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972781</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972608</link>
                        <pubDate>Fri, 23 Jul 2021 16:03:25 +0000</pubDate>
                        <description><![CDATA[I predict that if it is a tight as it appears to be, the insert that is screwed then pinned into the crank will unscrew before the pedal thread does. This has happened to me when I bought a ...]]></description>
                        <content:encoded><![CDATA[I predict that if it is a tight as it appears to be, the insert that is screwed then pinned into the crank will unscrew before the pedal thread does. This has happened to me when I bought a s/h bike that came with some "FREE" pedals. I told the fella I didn't want them, and he said "Just have them." I found out why when I got home. I needed to buy a new crankset.
As above, in future keep the pedal threads clean, lightly greased, and only lightly "nipped" up.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>TroutWrestler</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972608</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972589</link>
                        <pubDate>Fri, 23 Jul 2021 15:51:39 +0000</pubDate>
                        <description><![CDATA[@LD has it.
Remove the crank and use an 8mm hex socket in a vice. Use the crank as the lever and it’ll come off easily.]]></description>
                        <content:encoded><![CDATA[@LD has it.
Remove the crank and use an 8mm hex socket in a vice. Use the crank as the lever and it’ll come off easily.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>tonyf1</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972589</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972489</link>
                        <pubDate>Fri, 23 Jul 2021 14:34:39 +0000</pubDate>
                        <description><![CDATA[I’ve had a pedal come loose after tightening as hard as I could with a multi-tool
1. A multi-tool is only meant for emergency repairs. They are usually so small and flimsy that you can&#039;t t...]]></description>
                        <content:encoded><![CDATA[<blockquote> I’ve had a pedal come loose after tightening as hard as I could with a multi-tool </blockquote>
1. A multi-tool is only meant for emergency repairs. They are usually so small and flimsy that you can't torque things up very tight.
2. If it's an aluminium crank, the threads may have been damaged. I've removed pedals that have been fitted without any grease. The fretting between the crank threads and axle tend to weld them together and it's impossible to remove them without damaging the threads in the crank. If the threads are badly damaged, they'll come loose no matter how tight you tighten them. That's a completely different problem.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>thols2</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972489</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972471</link>
                        <pubDate>Fri, 23 Jul 2021 14:14:17 +0000</pubDate>
                        <description><![CDATA[Dezb, what’s the point of quoting me about allen key bending, I’m confused
I apologise. I have never bent or seen an allen key bending when removing a pedal I have fitted.
Even on my commut...]]></description>
                        <content:encoded><![CDATA[<blockquote>Dezb, what’s the point of quoting me about allen key bending, I’m confused</blockquote>
Even on my commuter, where they stay installed for years and are used almost daily in all weathers.
But yeah, I don't actually think they self tighten, just, due to the way the threads are, they don't come loose. I tighten them up with just bit of friction, so I know they're done up. But 54NM as recommended by SRAM is ridiculous. I honestly didn't think it needed that much explaining, so once again, I apologise.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>DezB</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972471</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972459</link>
                        <pubDate>Fri, 23 Jul 2021 14:00:56 +0000</pubDate>
                        <description><![CDATA[The self tightening theory is sound, but in practice it&#039;s not 100% reliable, obviously it helps, there&#039;s good reason for reverse threads and nobody would suggest changing it but it&#039;s not rea...]]></description>
                        <content:encoded><![CDATA[The self tightening theory is sound, but in practice it's not 100% reliable, obviously it helps, there's good reason for reverse threads and nobody would suggest changing it but it's not real world proof, I've had a pedal come loose after tightening as hard as I could with a multi-tool and the only real backpedalling I do is when lubing my chain so how the hell it happened remains unexplained, bearings silky smooth, axles not bent, go figure.
 Why do most pedal makers advise around 35nm, that's a shed load more than nipped up.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>greeny30</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972459</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972132</link>
                        <pubDate>Fri, 23 Jul 2021 09:55:05 +0000</pubDate>
                        <description><![CDATA[Crank off and in a vise for me. Allows you options to get a hex bit securely inserted and avoid risking a slip. And then when that doesn&#039;t work you can dismantle the pedal, grind flats into ...]]></description>
                        <content:encoded><![CDATA[Crank off and in a vise for me. Allows you options to get a hex bit securely inserted and avoid risking a slip. And then when that doesn't work you can dismantle the pedal, grind flats into the axle and do it that way.
I'm another for just hand tight and a bit on pedals. Never had one come loose this way and I've come across plenty of pedals on so tight that they're difficult to remove.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>luket</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11972132</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11971997</link>
                        <pubDate>Fri, 23 Jul 2021 08:22:58 +0000</pubDate>
                        <description><![CDATA[‘Self tighten’
They don’t self tighten, but if the threads were the opposite way around they definitely would self loosen, no matter how tight they were to start with.
The precessional forc...]]></description>
                        <content:encoded><![CDATA[‘Self tighten’
The precessional forces do mean that if they are adequately tight to start with they will stay tight.
Adequately tight, isn’t actually all that tight for an adult with a spanner.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>martymac</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11971997</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11971977</link>
                        <pubDate>Fri, 23 Jul 2021 08:10:43 +0000</pubDate>
                        <description><![CDATA[the self tightening thing is horseshit
It&#039;s called &quot;precession&quot;.]]></description>
                        <content:encoded><![CDATA[<blockquote>the self tightening thing is horseshit</blockquote>
It's called "precession".
<a href="https://en.wikipedia.org/wiki/Precession_%28mechanical%29#Bicycle_pedals">https://en.wikipedia.org/wiki/Precession_%28mechanical%29#Bicycle_pedals</a>
<img src="https://upload.wikimedia.org/wikipedia/commons/thumb/3/3b/Animation_of_mechanical_precession.gif/220px-Animation_of_mechanical_precession.gif" alt="" />]]></content:encoded>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/how-to-remove-a-pedal-stuck-in-a-carbon-crank/#post-11971977</guid>
                    </item>
							        </channel>
        </rss>
