<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Have I damaged my brakes - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sat, 04 Apr 2026 20:32:49 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: Have I damaged my brakes</title>
                        <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213739</link>
                        <pubDate>Tue, 23 Nov 2010 18:40:54 +0000</pubDate>
                        <description><![CDATA[they are ground, to make sure they are flat.]]></description>
                        <content:encoded><![CDATA[<p>they are ground, to make sure they are flat.
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>mkultr4</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213739</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213738</link>
                        <pubDate>Tue, 23 Nov 2010 18:37:04 +0000</pubDate>
                        <description><![CDATA[Not with an angle grinder
Most are cut from flat]]></description>
                        <content:encoded><![CDATA[<p>Not with an angle grinder</p>
<p>Most are cut from flat
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>TandemJeremy</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213738</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213737</link>
                        <pubDate>Tue, 23 Nov 2010 18:34:19 +0000</pubDate>
                        <description><![CDATA[its not rocket science. I done this hundreds of times cars,bikes.some of those raced on tracks you just be careful and use a micrometer and straight edge. how do you think rotors are made]]></description>
                        <content:encoded><![CDATA[<p>its not rocket science. I done this hundreds of times cars,bikes.some of those raced on tracks you just be careful and use a micrometer and straight edge. how do you think rotors are made
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213737</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213736</link>
                        <pubDate>Tue, 23 Nov 2010 18:27:45 +0000</pubDate>
                        <description><![CDATA[Using an angle grinder on a disc is wrong.  You will make the disc thinner thus weeker ( you do know there is a minimum thickness for a disc?), controlling how much material you remove will ...]]></description>
                        <content:encoded><![CDATA[<p>Using an angle grinder on a disc is wrong.  You will make the disc thinner thus weeker ( you do know there is a minimum thickness for a disc?), controlling how much material you remove will be difficult meaning you could end up with  brake judder.</p>
<p>its a stupid thing to do.</p>
<p>The grooves in the disc will simply mean it takes longer to bed pads in and will have no detriment once they are bedded in
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213736</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213735</link>
                        <pubDate>Tue, 23 Nov 2010 18:23:31 +0000</pubDate>
                        <description><![CDATA[Get angle grinder with abrasive disc and sand them out.
eh terrible advice.
if it scratched a bit leave it. if its deep groves replace it.
Nothing wrong with using an angle grinder if you k...]]></description>
                        <content:encoded><![CDATA[<p>Get angle grinder with abrasive disc and sand them out.</p>
<p>eh terrible advice.</p>
<p>if it scratched a bit leave it. if its deep groves replace it. </p>
<p>Nothing wrong with using an angle grinder if you know what your doing. Grooves will have no detriment to braking at all they will just wreck your new pads you've just put in.<br />
@ziggy yeah you could sand your rotor holes out and fill the one in between your nose and chin.
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213735</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213734</link>
                        <pubDate>Mon, 22 Nov 2010 19:35:31 +0000</pubDate>
                        <description><![CDATA[Is now the time to tell you the easy why of aligning the caliper?
Just loosen the caliper bolts, then hold the brake on and do the bolts up whilst still holding on the brake.
Usually results...]]></description>
                        <content:encoded><![CDATA[<p>Is now the time to tell you the easy why of aligning the caliper?</p>
<p>Just loosen the caliper bolts, then hold the brake on and do the bolts up whilst still holding on the brake.<br />
Usually results in a perfectly aligned caliper.</p>
<p>Sorry for not telling you that 2 hours ago  :-)
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>ziggy</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213734</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213733</link>
                        <pubDate>Mon, 22 Nov 2010 19:16:09 +0000</pubDate>
                        <description><![CDATA[Yes, the disc may be ever-so slightly bent and causing it to rub just a tiny bit.  It really doesn&#039;t matter.
I hate getting brakes right but when they are it makes soooo much difference to m...]]></description>
                        <content:encoded><![CDATA[<p>Yes, the disc may be ever-so slightly bent and causing it to rub just a tiny bit.  It really doesn't matter.</p>
<p>I hate getting brakes right but when they are it makes soooo much difference to my confidence, it's worth it.</p>
<p>Rachel
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>allthegear</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213733</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213732</link>
                        <pubDate>Mon, 22 Nov 2010 18:54:27 +0000</pubDate>
                        <description><![CDATA[Blimey that took an age to get lined up. It rubs a bit in one place as you spin the wheel is that ok? Done the front as well as they were looking low. Did what Yoshimi said about pushing the...]]></description>
                        <content:encoded><![CDATA[<p>Blimey that took an age to get lined up. It rubs a bit in one place as you spin the wheel is that ok? Done the front as well as they were looking low. Did what Yoshimi said about pushing the pads in and it worked a treat. </p>
<p>Yey me!
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>emsz</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213732</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213731</link>
                        <pubDate>Mon, 22 Nov 2010 16:51:07 +0000</pubDate>
                        <description><![CDATA[just align caliper as Yoshimi says it will be fine - you may ahave a stuck calipe rif only one side wore out. that is a right pain to fix.]]></description>
                        <content:encoded><![CDATA[<p>just align caliper as Yoshimi says it will be fine - you may ahave a stuck calipe rif only one side wore out. that is a right pain to fix.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>Junkyard</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213731</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213730</link>
                        <pubDate>Mon, 22 Nov 2010 16:48:27 +0000</pubDate>
                        <description><![CDATA[Sounds normal to me! Pump the brake a couple times for the pistons to reset be cautious the first couple of times you use the brake as they&#039;ll need to bed in... for me normally one long drag...]]></description>
                        <content:encoded><![CDATA[<p>Sounds normal to me! Pump the brake a couple times for the pistons to reset be cautious the first couple of times you use the brake as they'll need to bed in... for me normally one long drag and they're back to normal!
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>xc-steve</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/have-i-damaged-my-brakes/#post-2213730</guid>
                    </item>
							        </channel>
        </rss>
