Fox RLC adjuster pr...
[Closed] Fox RLC adjuster problems
4 Users
I've recently bout some F120 RLC off a mate and am having a problem with the above.
1. When the lockout is moved, it changes the setting on the compression dial.
2. I thought it may be dirt in the dials, so took them off, cleaned and reassembled but after a couple of hours at Lee Quarry, the lockout lever is now jammed.
According to this thread, the rlc knob design is flawed...
http://singletrackworld.com/forum/topic/stupid-fox-rlc-adjuster-knob
Any suggestions re either of above 2 problems?
Posted : 08/10/2012 6:35 am
 MSP
I had this problem, I used some silicon to keep the compression in the place I wanted.
Then when I was giving them a service I dropped the spring and one of the ball-bearings, so got some new ones, when I cam to fit them, found part of the old spring still in its hole. Haven't had the problem since. I now have some spare ballbearings and a spring.
I think its not a good design, and the spring and bearings get worn and need replacing after a while.
Posted : 08/10/2012 6:44 am
Cheers, sounds like a good idea....it u just use a blob of slicone sealant under the edge of the compression dial?
Posted : 08/10/2012 7:52 am
 LoCo
Generally it's dirt between the two dials and the lockout dial/the three bearings not being correctly located it onto the central boss of the top cap, that are the issues.
Posted : 08/10/2012 7:59 am
I have this problem. The compression dial just spins almost freely so if I turn the lockout the compression will move as well unless I use two hands and hold it in place.
I haven’t tried to sort it. As the small movements it makes on the dial appears to have no impact on the way the fork operates.
Posted : 08/10/2012 8:10 am
