<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Crank Q Factors - 168 / 172 - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sat, 04 Apr 2026 22:12:57 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: Crank Q Factors - 168 / 172</title>
                        <link>https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/#post-11224594</link>
                        <pubDate>Tue, 02 Jun 2020 19:08:39 +0000</pubDate>
                        <description><![CDATA[Yeah, you can always go wider and obviously probably won&#039;t notice 2mm each side wider. But it&#039;s possible to go too narrow and buy cranks that will foul your frame. Don&#039;t do that.]]></description>
                        <content:encoded><![CDATA[Yeah, you can always go wider and obviously probably won't notice 2mm each side wider. But it's possible to go too narrow and buy cranks that will foul your frame. Don't do that.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>Superficial</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/#post-11224594</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/#post-11224406</link>
                        <pubDate>Tue, 02 Jun 2020 16:54:47 +0000</pubDate>
                        <description><![CDATA[Some narrower cranks won&#039;t clear the chain stays as they are now wider for fatter tyres.
My xtr m9000 cranks (narrow q factor) wouldn&#039;t fit a scandal but the xtr m9020 would (wider q factor...]]></description>
                        <content:encoded><![CDATA[Some narrower cranks won't clear the chain stays as they are now wider for fatter tyres.
My xtr m9000 cranks (narrow q factor) wouldn't fit a scandal but the xtr m9020 would (wider q factor)]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>damascus</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/#post-11224406</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/#post-11224397</link>
                        <pubDate>Tue, 02 Jun 2020 16:50:37 +0000</pubDate>
                        <description><![CDATA[Perfect, I was hoping that was the case.
Thanks]]></description>
                        <content:encoded><![CDATA[Perfect, I was hoping that was the case.
Thanks]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>homebrewjunkie</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/#post-11224397</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/#post-11224292</link>
                        <pubDate>Tue, 02 Jun 2020 16:00:37 +0000</pubDate>
                        <description><![CDATA[Just means you have the option of running the narrower Q factor option that some prefer (tend to be from road background). Nothing to stop you using the wider Q-Factor at all.]]></description>
                        <content:encoded><![CDATA[Just means you have the option of running the narrower Q factor option that some prefer (tend to be from road background). Nothing to stop you using the wider Q-Factor at all.]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>sillyoldman</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/#post-11224292</guid>
                    </item>
				                    <item>
                        <title>Crank Q Factors - 168 / 172</title>
                        <link>https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/#post-11224089</link>
                        <pubDate>Tue, 02 Jun 2020 14:39:36 +0000</pubDate>
                        <description><![CDATA[I recently purchased a new frame and the crank q factor is 168, which limits the Shimano cranks available as most are 172, with the exception of the XRT range.
Does it really matter? Or can...]]></description>
                        <content:encoded><![CDATA[I recently purchased a new frame and the crank q factor is 168, which limits the Shimano cranks available as most are 172, with the exception of the XRT range.
Does it really matter? Or can I ignore the 168 and run Shimano XT cranks with a q factor of 172?
Cheers]]></content:encoded>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/crank-q-factors-168-172/#post-11224089</guid>
                    </item>
							        </channel>
        </rss>
