Cracked nipple, any...
[Closed] Cracked nipple, any secret tips...
 DT78
[#6350594]
to remove without cutting the spoke? It's a bladed one and I don't have a spare....factory built prolite bracciano
Whole nipple has correded / cracked off. Taking rim tape off and the spoke is too far through the nipple to use a screw driver
Any other ideas before I try to source a replacement spoke and cut it out?
Posted : 19/07/2014 12:38 pm
get an old screwdriver and file/cut a slot into the centre. Then you should be able to use it.
Posted : 19/07/2014 12:44 pm
 DT78
Good call. Pretty seized though but worth a go for a rainy afternoon job
Posted : 19/07/2014 1:03 pm
 DT78
Failed, won't budge. Now with the LBS. £20 to true a wheel plus a likely £5 for spoke and nipple. Ouch.
It'd better be damn perfect for those prices.
Posted : 19/07/2014 3:02 pm
If you'd been lucky I guess you could've loosened all the others until the tension was removed from it but I'd pay somebody £25 for that as I think it'll be a nightmare of seized nips and swearing
(I'd also ask them to rebuild with new nips, TBH - are these ones alloy ?)
Posted : 19/07/2014 9:09 pm
 DT78
yep they were alloy. tbh they were fine for two years use, think riding through floods did it.
If I had the spare spokes I would just cut the seized ones out and replace, but I figured I'd have to try to track the right length down, then probably buy in bulk.
So yes, probably worth it, as the wheel is clean, no cassette, no tyre or rim strip and loosened off (other than the one offending spoke) I was expecting a tenner
Posted : 19/07/2014 10:06 pm
Sudocrem might work.
Posted : 19/07/2014 10:10 pm
Twenty quid seems steep for a wheel true.
Posted : 19/07/2014 10:14 pm
only if you're a cat4 racer
Posted : 19/07/2014 10:26 pm
bikeneil - Member
Ohh I dont know, cracked ally nipple, others probably not too far behind, there's a possibility some will be ceased, could turn out to be a nightmare.
Posted : 19/07/2014 10:30 pm
