Looking at these, anybody know the following:
What is the likely spring that comes with them? I weigh around 70kg, would I need to swap it out for a lighter one?
How quick is it to wind the travel down using the DPC? I believe u-turn takes a lot of winding, is the DPC the same or is it just a quick turn and its dropped?
Cheers.
You should be ok with the standard spring, the DP coil system just works by flicking the lever and compressing the forks they'll just stay at the lower or higher position when the rebound.
It feels pretty nice as a travel adjust system and should be really reliable as it's coil.
Feel free to contact me for a quote 😉
quick turn and its dropped, like old ETA on Marzocchi's. At 70kg you may well have to swap....
Sounds good, didnt want to be winding away at an adjuster at the bottom of a climb!
YGM LoCo. 8)
