<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Can I replace a Campag front mech with one from an MTB? - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sun, 05 Apr 2026 02:54:17 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: Can I replace a Campag front mech with one from an MTB?</title>
                        <link>https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870820</link>
                        <pubDate>Sun, 19 Jan 2014 21:38:24 +0000</pubDate>
                        <description><![CDATA[~Yes.
the curve of the mech may mean that it has to be a touch high. I like mine with the absolute minimum space between mech and big ring e.g. a couple of mil max. Even my nasty QS Veloce s...]]></description>
                        <content:encoded><![CDATA[<p>~Yes.<br />
the curve of the mech may mean that it has to be a touch high. I like mine with the absolute minimum space between mech and big ring e.g. a couple of mil max. Even my nasty QS Veloce shifters will run almost anything and the older stuff, e.g. my Record 8 speeds have never failed and I run all sorts of weird and wonderful junk. Even my old Campag matchbox front mech works.<br />
Of course you may have the one front mech that doesn't work. If in doubt something older is easier to set up.<br />
I also use normal double mechs on my triple Campag set ups. 1 has used a modern Centaur one and the other an early 70's Super Record.
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>mattsccm</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870820</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870819</link>
                        <pubDate>Sun, 19 Jan 2014 20:58:07 +0000</pubDate>
                        <description><![CDATA[With a bit of fiddling about it should work just fine.
I used to run an old LX (1997ish)front mech with Veloce 9sp shifters (2007ish)- what sort of triple? Mine had on olde worlde mtb chains...]]></description>
                        <content:encoded><![CDATA[<p>With a bit of fiddling about it should work just fine.<br />
I used to run an old LX (1997ish)front mech with Veloce 9sp shifters (2007ish)- what sort of triple? Mine had on olde worlde mtb chainset with 46-34-24 and worked a treat.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>Pickers</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870819</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870818</link>
                        <pubDate>Sun, 19 Jan 2014 20:50:07 +0000</pubDate>
                        <description><![CDATA[This is at least 10 years old if that makes any difference]]></description>
                        <content:encoded><![CDATA[<p>This is at least 10 years old if that makes any difference
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>FOG</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870818</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870817</link>
                        <pubDate>Sun, 19 Jan 2014 20:43:51 +0000</pubDate>
                        <description><![CDATA[May be worth a try but the curve on the mech plate will be much tighter which is the most likely source of incompatability - will have to sit way too high to work.]]></description>
                        <content:encoded><![CDATA[<p>May be worth a try but the curve on the mech plate will be much tighter which is the most likely source of incompatability - will have to sit way too high to work.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>cynic-al</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870817</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870816</link>
                        <pubDate>Sun, 19 Jan 2014 20:43:32 +0000</pubDate>
                        <description><![CDATA[i am using a 105 triple on my campag double equipped road bike.
I don&#039;t know if things have changed re compatibility in more recent years as this is 5-6 years old 9spd.]]></description>
                        <content:encoded><![CDATA[<p>i am using a 105 triple on my campag double equipped road bike. </p>
<p>I don't know if things have changed re compatibility in more recent years as this is 5-6 years old 9spd.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>mrmo</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870816</guid>
                    </item>
				                    <item>
                        <title>Can I replace a Campag front mech with one from an MTB?</title>
                        <link>https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870815</link>
                        <pubDate>Sun, 19 Jan 2014 20:27:14 +0000</pubDate>
                        <description><![CDATA[Sorry to ask about road bikes but the front mech on my campag 9spd triple winter bike has cried enough. Can I simply replace it with an MTB shimano one from the spares box or am I stuck with...]]></description>
                        <content:encoded><![CDATA[<p>Sorry to ask about road bikes but the front mech on my campag 9spd triple winter bike has cried enough. Can I simply replace it with an MTB shimano one from the spares box or am I stuck with finding a compatible campag one?<br />
There is a lot of trim in the gear levers so I was hoping I might get away with it.
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/can-i-replace-a-campag-front-mech-with-one-from-an-mtb/#post-5870815</guid>
                    </item>
							        </channel>
        </rss>
