Brakeforce One best...
[Closed] Brakeforce One bestest ever brakes - geekery
26 Users
So, following on from this article on the new best ever brakes(TM) from Brakeforce one:
http://www.singletrackworld.com/2011/09/eurobike-2011-brakeforce-one-brakes
and the more technical detail here:
http://www.bikebiz.com/index.php/news/read/schoolboy-designs-most-powerful-brake-ever/011821
"The problem with standard disc brakes is that you have either a fast reaction time, or power, but you can't have both," said Wauhoff.
"This is because of the diameters of the pistons. I thought it should be possible to push the pads to the disc fast with a big piston and then get a small piston to exert a lot of pressure. I built a brake booster to test this theory. It worked."
Anyone have any suggestions how it's actually done - eg how are they getting the variable effective piston size so that they can move lots of fluid early on to get the pads to the rotor and then less once in contact to get more power?
Posted : 08/09/2011 8:24 am
 berk
On the video there was some plans on his phone (approx 60s in) Seemed like there was a smaller piston within the main piston, which I suspect explains why the calliper looks so chunky
Posted : 08/09/2011 8:31 am
To me it looks like it'll be over complex with too many seals etc. to stick/maintain and generally cause grief when subjected to shitty conditions, day in, day out
Hope I'm wrong
Posted : 08/09/2011 8:36 am
Interesting, but it's not encouraging that he's got it backwards - a small piston moves fast, a big piston exerts lots of pressure. The complete lack of any technical detail doesn't really help in this respect (is he keeping it secret to avoid being copied? does he realise that anybody who wants to copy will just get one and reverse engineer?)
Of course they're not the first brakes with varying mechanical advantage
Posted : 08/09/2011 8:39 am
 DrP
THe first post is my thoughts - a 'telescopic' piston.
First piston provides the majority of movement to get the pad to the disc, second piston provides the force.
In reality, it would be the [b]smaller[/b] of the pistons that would push the pad out quickest (i.e. i expect the inner piston moves first), then the [b]larger[/b] piston would come into play (larger piston surface area would provide less movement, but more force)
Clever idea. Of course I had a similar once when I was 4.
DrP
Posted : 08/09/2011 8:41 am
OK, to clear up. A large piston at the lever will move the pads quicker than a small one but with less power. So the system uses the large piston first then transfers to the smaller one.
Oh and the guy is clearly spud from trainspotting 😉
Here's the cross-section pic of the brake lever piston
So it looks like the large outer bit moves first and then the much smaller inner piston moves once the pad contacts the rotor though I'm not sure how the system transfers from one piston to the other as left free, the small piston would move first (less resistance)
I can't listen to the video in which presumably he explains it - anyone care to summarise?
Posted : 08/09/2011 8:53 am
who cares? its NEW and ANODIZED!!!!!!
Posted : 08/09/2011 9:08 am
It's old hat. Alloy race jacks for lifting track cars have been using this for a long time. First push on the lever takes up the free space & then the "low gear" takes over.
Fine until the seals gum up & something starts to stick 😀 My Hope's have never been short on modulation & have power in spades. What's next ? Triple/quad concentric pistons for more feel. Anyone working on ABS for bicycles ?
Why fix it etc...........Ah...that's better 😀
Ededited to korekt my spellin
999 euros though 🙁
Posted : 08/09/2011 9:09 am
 5lab
can't you just use bite point adjustment to do the same thing? I can see how this is useful on rim brakes, where you need the pad a significant distance from the braking surface when not on the brakes, but on a disk brake I've not seen the issue. Mine start applying braking force approx 25% through the lever travel, which is fine by me.
how do you force the initial bit of fluid to go into the small diameter piston? Wouldn't it go into both pistons equally?
Posted : 08/09/2011 9:23 am
You should have tried Kielder last week - I would have traded my first born for moving the pads further from the rotor 🙂
Posted : 08/09/2011 9:25 am
 D0NK
Considering at the merest hint of mud my discs get that awful scrr scrr scrr sound of rotor/mud/pad contact I'd quite like disc pads to be further from braking surface too.
 5lab
fair enough, looks liek some folk do want a pad thats further from the rotor, but doesn't servo wave (which puts variable pad movement into the lever) do that for you? if you mess about with the angle of the cylinder in the lever you should be able to get the fluid-sent-per-mm-of-lever-travel to ramp down significantly through the lever travel?
Posted : 08/09/2011 9:28 am
 D0NK
but doesn't servo wave...do that for you?
not significantly (at all?) no
Edit Servowave does adjust leverage* vs lever travel which is nice, the screw in thing (freestroke?) I think was supposed to alter the pad distance but I can't tell any difference.
*or atleast lever feel, I know I can get my XT brakes setup to feel just right
Posted : 08/09/2011 9:30 am
I think you're missing the point. With a dual piston setup you can have LOADs more power than current designs because you don't have to worry about clearance or actually moving the pads to the rotor. Several of you say that pad clearance isn't an issue but that's because pads retract enough to stop that. You could make current brakes loads more powerful by reducing the clearance and making the master cylinder smaller but they'd always rub which would be annoying.
The dual system allows you to have a very small working piston (eg lots of power) without clearance issues.
Yes, that's another way of doing the same sort of thing (changing linear distance the piston travels instead of the area.
Posted : 08/09/2011 9:33 am
 5lab
actually, reading a bit further, it sounds like there are 2 pistons in the lever, not in the caliper. This is why the small piston exerts the pressure and the large one does the distance, and also why you can change the balance between the two using a dial on the lever. I guess its the same as servowave, but actuated hydrolically, not mechanically
Posted : 08/09/2011 9:51 am
I'm sure this has been done before at the calliper end though?
Even hope made simlar claims about the m4 and m6 having different sized pistons to maintain some modulation.
Posted : 08/09/2011 9:56 am
Pointing to a knob on one of the levers, Wauhoff said: "Space between the pads and the disc can be regulated with this wheel, so if you hear 'bling, bling, bling' you make a few turns and the rubbing noise disappears."
like hope c2's ??
Why won't he have the same issues that all closed systems used to have - expanding hot fluid eventually locks the brake out?
Dave
Posted : 08/09/2011 10:00 am
Due to the volume of the piston/s?
Nay sayers perhaps just need to hold fire on their dismissals until they're heard some reviews. This system has had investment and industry interest, so let's just see how it goes.
Everything new, different or interesting tends to be dismissed until it's had a chance to prove itself. If everyone had always dismissed new directions like they tend to get dismissed on here, technology wouldn't have progressed much beyond fire.
Posted : 08/09/2011 10:05 am
but for any given volume of piston, if the fluid fills it completely, then if that fluid expands, it will push the pistons out. If this happens enough, there will no longer be room for him to adjust with his little wheel.
Or are we saying that the lever piston is so massive that even if the fluid expands A LOT, there is still room to wind the lever and adjust? - a brute force technique, if you like.
Dave
Posted : 08/09/2011 10:09 am
I suggested it as more volume takes longer to boil than less volume. I don't really know, hence the question mark. My knowledge of the finer point of hydraulics is limited to pulling the lever or pressing the pedal and hoping I stop.
Posted : 08/09/2011 10:13 am
for the record, I wasn't dismissing it... just interested in how it works, and how he has got around some of the problems of a closed system.
They used to be the norm, and gave you the advantage of being able to dial out pad rub, but the boiling and locking issue killed them off. If he's found a way out of that then good luck to him.
Will he try to make a go of it, or sell out to SRAM or Shimano?? High risk going against those guys. SRAM seem more likely to hoover him up for a big payout, just like they did with Avid.
Dave
Posted : 08/09/2011 10:24 am
The reservoir on a open brake has a limited size too, so it can only cope with so much fluid expansion before the pads can no longer retract properly. It's just that the available volume is generally large enough to cope with pretty much any normal use.
It's perfectly possible for a closed system to have sufficient volume adjustment, although it may need a lot of adjusting.....
Posted : 08/09/2011 10:45 am
Davesport +1............
ABS for bikes surely within the next 5 years? They said it would never happen on motorbikes but surely not on humble 'pushbikes'????
I don't think I'd want ABS... sometime you want to lock your wheels!
skids are for kids, but what about endos and stoppies?
Dave
Posted : 08/09/2011 10:50 am
ABS would be useless on a mountain bike.
Posted : 08/09/2011 10:56 am
Yes, ABS and loose surfaces are incompatible.
Wouldn't bet against seeing it being made available on commuting and city bikes at some point in the future mind.
Posted : 08/09/2011 11:00 am
I've never felt that i've had a slow reaction time with disk brakes, is this really a problem that needs solving and its because i'm a shit rider that i've never suffered from it?
Posted : 08/09/2011 11:04 am
I think the point is that you would have a slow reaction time if the pads were far away from the rotors.
His system lets you have the pads a long way away (so they don't rub), and still get them across that distance to the rotor with enough power to stop you properly.
If it works, it sounds good.
Dave
Posted : 08/09/2011 11:11 am
It's nothing to do with reaction time. The theoretical benefit of the design is that you can have much more power without the drawback of rotor rubbing or a lever that has to pull to the bars before doing any braking.
As to the expansion thing, yes, he basically said that the oil volume is sufficient that heat expansion will not significantly affect clearance. I'm slightly sceptical that the volume will be that much bigger than say Hope C2s were but then again, my Hope C2s never had any issue with pumping up either. I know that the DHers of the time though did have issues - they'd start races with loads of pad clearance so that as they pumped, the wheels could still turn 😯
Posted : 08/09/2011 11:13 am
For someone that has Avid Elixer's that rub constantly as the pads have to be so close to the disc to work I would be certainly interested. Even the Avid race tech's couldn't make the brakes work without rubbing. Like most things the technology is out there and it is the bringing together of ideas and actually getting them to work. Good on the fella, competition is always good as too many of the big firms hold back improvements so they can slowly trickle them out over the years, bolt through hubs a fine example.
Posted : 08/09/2011 1:10 pm
I presume the acres of clearance it sounds like they've got, means this won't happen. A small amount of expansion at the pad will barely be noticed at the lever. If you really do hammer it, you wind them out, c2 style
Posted : 08/09/2011 6:22 pm
999 Euros? Really?
i hope that's front [i]and[/i] rear!
Posted : 08/09/2011 8:09 pm
 5lab
they may have acres of clearance, but it sounds like the 'crossover' point between big movement and big pressure is manually set. if you set that up right (so it kicks in just as the pads touch the disk), it only takes a tiny bit of expansion for the pads to hit the disk in 'high movement' mode, and you'll never get into the 'high power' part of the lever stroke..
Posted : 08/09/2011 9:26 pm
999 euros you say. Don't worry, when the euro zone crashes and takes all of their economies with it you'll pick them up for peanuts 😆
Posted : 08/09/2011 9:39 pm
Don't Ashima already do a twin piston with a 14mm inner and 22 mm outer piston
Posted : 08/09/2011 11:09 pm
That's twin piston at the caliper though
http://bicycling.com/blogs/thestraightdirt/2011/03/17/first-look-ashima-disc-brakes/
The first is called the APV, and it uses a concentric twin-piston design for two-stage braking. When the lever is activated the inner, 14mm piston contacts the rotor first, and as more pressure is applied the outer, 22mm piston ring kicks in.
Posted : 09/09/2011 7:58 am
I thought that ABS was standard on bikes from Halfords or is that they set their brakes up not to stop you.
Posted : 09/09/2011 8:47 am
Telescopic pistion is prob the best way to describe the brake. Hope it works out for him and don't get shafted by the big players.
"DrP - Member
In reality, it would be the smaller of the pistons that would push the pad out quickest (i.e. i expect the inner piston moves first), then the larger piston would come into play (larger piston surface area would provide less movement, but more force)
ARACER "Interesting, but it's not encouraging that he's got it backwards - a small piston moves fast, a big piston exerts lots of pressure"
Clubber "OK, to clear up. A large piston at the lever will move the pads quicker than a small one but with less power. So the system uses the large piston first then transfers to the smaller one."
sorry to say but your are all wrong! Clubber is the most right as I belive that how the brake is desgined,
But you/I can't be 100% with out knowing the size of the caliper piston(s) to size of the master ones,size of cambers,hose etc.
You can have a big piston 30mm dia but if the one on the other end is bigger at 60mm it not going to move it as far as a smaller 15mm piston.
Clubber "So it looks like the large outer bit moves first and then the much smaller inner piston moves once the pad contacts the rotor though I'm not sure how the system transfers from one piston to the other as left free, the small piston would move first (less resistance)"
If i remember rightly it to do with pistion "contact face" area and camber volume.
Looking at the pic of cross section that Clubber posted,I would say that the "bigger pistion" has a slightly biger area than the small one with the small pistion in it's own little chamber. the fluid/pressure as to travel down the resticted hole (less fluid/more press) into a bigger chamber (more fluid/less press)so should not move ahead of the bigger piston but [u]with it[/u] till the big piston hits it stops/travel limit and at that point all fluid/pressure is on the small piston for that to keep moving.
It's all in the Maths!
Posted : 09/09/2011 10:05 am
http://r2-bike.com/BrakeForceOne-Scheibenbremse-HINTEN
377 euro an end
Posted : 17/09/2011 8:30 am
I have just bought myself a set of Brake Force One brakes and after the first rides I have to say I'm really impressed. I got mine from this shop: http://www.starbike.com/p/Brake-Force-One-disc-brake-4727-en
Until now I had Hope 4-piston brakes on my Santa Cruz (which are anything but weak) but the Brake Force One beat them hands down. I was able to brake smoothly with one finger even in steep downhill sections. The only bad aspect is probably their price tag - 390 € per front or rear brake - but my Hope brakes weren't exactly cheap either...
Posted : 18/12/2011 4:00 pm
u registered just to spam this?
Posted : 18/12/2011 4:10 pm
£330 odd per end. No chance. at all. ever.
Posted : 18/12/2011 4:13 pm
Trailgeek - pics and maybe something to show you're not just spamming... 😉
Posted : 18/12/2011 5:47 pm
Guess not.. More astroturfing I reckon 🙄
Posted : 22/12/2011 5:16 pm
