Best mudguard/flap ...
[Closed] Best mudguard/flap for 2020 fox36
13 Users
After getting far too much mud in my eyes the other day I'm looking at buying a mudguard/flap for my Fox36 fork.
It's a 2020 fork and I think it has two bolt holes on the back of the fork bridge.
Any recommendations.
Posted : 16/10/2020 8:47 am
RRP Bolt on.
Posted : 16/10/2020 8:59 am
RRP for full length.
Syncros for short.
Posted : 16/10/2020 9:02 am
Yep. RRP bolt on. Shorter version. Long one can get a bit flappy in the rough stuff.
Edit after seeing above post from SSS. The shorter RRP I'm suggesting is still longer than the syncros or other mud flap types.
Posted : 16/10/2020 9:03 am
I have the rrp proguard bolt on shorter mudguard, and the cable tie longer version on my two bikes.
Both work well, the bolt on is much neater
Posted : 16/10/2020 9:05 am
RRP bolt on would be my vote. Far cheaper than the Mojo equivalent too
Posted : 16/10/2020 9:08 am
RRP bolt on long.
Doesn't flap at all (you do have to do the bolts up surprisingly tight)
Supposedly the syncros one is useless
Posted : 16/10/2020 9:09 am
RRP bolt on on mine.
Posted : 16/10/2020 9:19 am
Cheers all.
Ordered the RRP bolt on mini
Posted : 16/10/2020 10:36 am
RRP bolt on.
The big one, it's nearly winter after all.
[url= https://live.staticflickr.com/65535/49110603121_c4c73c4365_b.jp g" target="_blank">https://live.staticflickr.com/65535/49110603121_c4c73c4365_b.jp g"/> [/img][/url]
Just be aware, there may be fit issues if the fork offset is particularly short
Posted : 16/10/2020 10:39 am
Crud XL.
Doesn't use the bolt holes, but it's brilliant. I can ride mud without fear of any of it going into my eyes and sticking to my contact lenses. Only wore Oakley's again in the late spring until a few weeks ago as it doesn't stop Kamikaze flies.
Posted : 16/10/2020 11:44 am
Just changed my standard RRP for the max version. Had picked up the standard version by mistake the first time.
Much better coverage on 29r wheels. Did a few test runs flat out through some deep puddles and nothing got through. Doesn’t seem to ‘flappy’
Posted : 18/10/2020 7:30 pm
The "long one" in cable tie form is the Max Protection, and the "long one" in bolt-on form is the Standard.
Mini = 388mm, bolt-on only
Standard = ~500mm in both
Max Protection = 582mm, cable tie only
Posted : 19/10/2020 12:19 am
Much as I like Syncros product and have a syncros guard on most of our family forks, i actually managed to get a rock stuck between the fender and stanction. Happened the same crash I broke a wrist so killing my Kashima was the icing on the cake.
The lack of seal coverage is a bit of an oversight and the 2021 fox 36/38 is a much better solution..
Whilst it's great to not have cable ties etc the Syncros is still mostly effective for damp conditions.
That RRP guard looks ace as a winter guard and much better than the mudhugger I have on my hardtail
Posted : 19/10/2020 3:01 am
