<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									20mm rigid fork - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sat, 04 Apr 2026 19:32:11 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: 20mm rigid fork</title>
                        <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553863</link>
                        <pubDate>Thu, 12 Jan 2012 16:42:08 +0000</pubDate>
                        <description><![CDATA[Bolt through provides a huge increase in torsional stiffness which is the main benefit, nothing to do in the majority of cases with suspension, that would only really be an issue if the lowe...]]></description>
                        <content:encoded><![CDATA[<p><br />
Problem is, bolt-thru is really good for stiffening up sloppy suspension forks. In theory, a rigid fork shouldn't move so much, so doesn't need to be bolt-thru </p>
<p>Bolt through provides a huge increase in torsional stiffness which is the main benefit, nothing to do in the majority of cases with suspension, that would only really be an issue if the lowers were separate on each leg rather than bridged</p>
<p>Main benefit is felt in steering / tracking precision IME
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>cr500dom</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553863</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553862</link>
                        <pubDate>Thu, 12 Jan 2012 10:45:29 +0000</pubDate>
                        <description><![CDATA[And for stopping your wheel loosening under braking, which can apparently happen with QRs/discs.
X-lite 15mm carbon fork appears to be vapourware.
Andy]]></description>
                        <content:encoded><![CDATA[<p>bolt-thru is really good for stiffening up sloppy suspension forks</p>
<p>And for stopping your wheel loosening under braking, which can apparently happen with QRs/discs.</p>
<p>X-lite 15mm carbon fork appears to be vapourware.</p>
<p>Andy
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>ratherbeintobago</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553862</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553861</link>
                        <pubDate>Thu, 12 Jan 2012 10:09:45 +0000</pubDate>
                        <description><![CDATA[The salsa fork might be quite nice on a simple. Id guess that 470 mm is the about the same as sag adjusted 120-130 mm suspension fork so spot on.
I think the DMR at 440 mm is like a 100 mm ...]]></description>
                        <content:encoded><![CDATA[<p>The salsa fork might be quite nice on a simple. Id guess that 470 mm is the about the same as sag adjusted 120-130 mm suspension fork so spot on. </p>
<p>I think the DMR at 440 mm is like a 100 mm suspension fork with sag. </p>
<p>Not sure if the rake would be different on the salsa being a 29’r fork, (would this matter to much?) but might be worth dropping an email to Cotic (or Sasla) to ask
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>Sodajim</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553861</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553860</link>
                        <pubDate>Thu, 12 Jan 2012 09:42:19 +0000</pubDate>
                        <description><![CDATA[Or a 9mm QR?]]></description>
                        <content:encoded><![CDATA[<p>Or a 9mm QR?
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>sv</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553860</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553859</link>
                        <pubDate>Thu, 12 Jan 2012 09:16:16 +0000</pubDate>
                        <description><![CDATA[How about a nutted 9mm axle hub?  I have a buddy who uses one in the standard Cromoto.]]></description>
                        <content:encoded><![CDATA[<p>How about a nutted 9mm axle hub?  I have a buddy who uses one in the standard Cromoto.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>simon1975</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553859</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553858</link>
                        <pubDate>Wed, 11 Jan 2012 15:27:27 +0000</pubDate>
                        <description><![CDATA[well, you could view it as a very strong trail fork...
Choices are a bit limited really, X-Lite and On One are rumoured to be bringing out bolt-thru rigid forks.
Problem is, bolt-thru is rea...]]></description>
                        <content:encoded><![CDATA[<p>well, you could view it as a very strong trail fork...</p>
<p>Choices are a bit limited really, X-Lite and On One are rumoured to be bringing out bolt-thru rigid forks.<br />
Problem is, bolt-thru is really good for stiffening up sloppy suspension forks. In theory, a rigid fork shouldn't move so much, so doesn't need to be bolt-thru.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>ir_bandito</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553858</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553857</link>
                        <pubDate>Wed, 11 Jan 2012 14:49:18 +0000</pubDate>
                        <description><![CDATA[I think the DMR is a jump bike fork??]]></description>
                        <content:encoded><![CDATA[<p>I think the DMR is a jump bike fork??
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>tails</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553857</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553856</link>
                        <pubDate>Wed, 11 Jan 2012 14:28:08 +0000</pubDate>
                        <description><![CDATA[I think the Salsa is about 470mm.
[urlTrailblade is 440mm]]></description>
                        <content:encoded><![CDATA[<p>I think the Salsa is about 470mm.</p>
<p>DMR Trailblade is 440mm
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553856</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553855</link>
                        <pubDate>Wed, 11 Jan 2012 14:24:58 +0000</pubDate>
                        <description><![CDATA[Thanks Simon it looks the ticket, it says 29er but I&#039;ll look at a to c lengths!]]></description>
                        <content:encoded><![CDATA[<p>Thanks Simon it looks the ticket, it says 29er but I'll look at a to c lengths!
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553855</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553854</link>
                        <pubDate>Wed, 11 Jan 2012 14:18:15 +0000</pubDate>
                        <description><![CDATA[]]></description>
                        <content:encoded><![CDATA[<p>http://salsacycles.com/components/cromoto_grande_maxle/
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/20mm-rigid-fork/#post-3553854</guid>
                    </item>
							        </channel>
        </rss>
