<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									10 speed chain on a 9 speed train - will it work? - Bike Forum				            </title>
            <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/</link>
            <description>Singletrack World Magazine Forum. Come for the bikes, stay for the boll**ks</description>
            <language>en-GB</language>
            <lastBuildDate>Sun, 05 Apr 2026 03:08:57 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Re: 10 speed chain on a 9 speed train - will it work?</title>
                        <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224955</link>
                        <pubDate>Fri, 07 Jun 2013 17:57:39 +0000</pubDate>
                        <description><![CDATA[Arse
But Thanks lads]]></description>
                        <content:encoded><![CDATA[<p>Arse</p>
<p>But Thanks lads
</p>]]></content:encoded>
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>gwaelod</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224955</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224954</link>
                        <pubDate>Fri, 07 Jun 2013 13:41:21 +0000</pubDate>
                        <description><![CDATA[You might not die but your gears won&#039;t work.  Crankrider is right, the pull ratio is different.]]></description>
                        <content:encoded><![CDATA[<p>I'm trying to figure out if I'll die if I install a 10sp XT mech on an old 8sp XT setup, the gradual intention being to slowly migrate it to a full 10sp set up as bits finally give up the ghost.</p>
<p>You might not die but your gears won't work.  Crankrider is right, the pull ratio is different.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>qtip</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224954</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224953</link>
                        <pubDate>Fri, 07 Jun 2013 13:29:44 +0000</pubDate>
                        <description><![CDATA[That cant / wont happen.
Right:
8&amp;9 Spd chains = Exactly the same
10 spd Chain = narrower EXTERNALLY because they had to decrease the spacing between teeth on the cassette to fit the ext...]]></description>
                        <content:encoded><![CDATA[<p>That way you don't risk the 10sp chain keying it self to the 9 speed transmission and not working when you go fully 10sp </p>
<p>That cant / wont happen.</p>
<p>Right:<br />
8&amp;9 Spd chains = Exactly the same<br />
10 spd Chain = narrower EXTERNALLY because they had to decrease the spacing between teeth on the cassette to fit the extra gear on. - Use the 10spd chain with 8, 9 or 10 spd.</p>
<p>10 spd mech however = different story maybe - different cable pull ratios?<br />
11spd chain = 0.1mm smaller internally, not sure externally. 11spd only if you are being correct.</p>
<p>10 spd derailleur on 8 spd setup may not work due to cable pull ratios.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>crankrider</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224953</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224952</link>
                        <pubDate>Fri, 07 Jun 2013 13:22:51 +0000</pubDate>
                        <description><![CDATA[Sorry crap wording.  That&#039;s what I meant by &quot;keying&quot;.]]></description>
                        <content:encoded><![CDATA[<p>The only reason not to do it is if you're likely to wear that chain out in a couple of months</p>
<p>Sorry crap wording.  That's what I meant by "keying".
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>jairaj</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224952</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224951</link>
                        <pubDate>Fri, 07 Jun 2013 12:29:55 +0000</pubDate>
                        <description><![CDATA[That makes no sense, the spacing of the teeth doesn&#039;t change. The only reason not to do it is if you&#039;re likely to wear that chain out in a couple of months, they are totally compatibl...]]></description>
<p>That makes no sense, the spacing of the teeth doesn't change. The only reason not to do it is if you're likely to wear that chain out in a couple of months, they are totally compatible.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>njee20</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224951</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224950</link>
                        <pubDate>Fri, 07 Jun 2013 12:27:11 +0000</pubDate>
                        <description><![CDATA[is there a some sort of 8/9/10 speed compatability flowchart somewhere online - it would save everyone a lot of bother -
I&#039;m trying to figure out if I&#039;ll die if I install a 10sp XT mech on ...]]></description>
                        <content:encoded><![CDATA[<p>is there a some sort of 8/9/10 speed compatability flowchart somewhere online - it would save everyone a lot of bother - </p>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224950</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224949</link>
                        <pubDate>Fri, 07 Jun 2013 12:21:09 +0000</pubDate>
                        <description><![CDATA[Patriotpro  email me. I&#039;ve got a just under .75% worn SRAM you can have for postage and karma]]></description>
                        <content:encoded><![CDATA[<p>Patriotpro  email me. I've got a just under .75% worn SRAM you can have for postage and karma
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>Scapegoat</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224949</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224948</link>
                        <pubDate>Fri, 07 Jun 2013 12:04:52 +0000</pubDate>
                        <description><![CDATA[I run a 10 speed chain (KMC) on a 9 speed chainset, works perfectly]]></description>
                        <content:encoded><![CDATA[<p>I run a 10 speed chain (KMC) on a 9 speed chainset, works perfectly
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>Dales_rider</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224948</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224947</link>
                        <pubDate>Fri, 07 Jun 2013 11:46:03 +0000</pubDate>
                        <description><![CDATA[b r - it&#039;s because i&#039;ve had the whole drivetrain since new and it&#039;s all really tired. I&#039;m gonna go 2 x 10 but can&#039;t afford to do it in one wild swoop. If I bought a 9-speed chain, I would...]]></description>
                        <content:encoded><![CDATA[<p>b r - it's because i've had the whole drivetrain since new and it's all really tired. I'm gonna go 2 x 10 but can't afford to do it in one wild swoop. If I bought a 9-speed chain, I would only be buying again in the next couple of months when I mustered the fundage to get the rest of the drivetrain.</p>
<p>Mate</p>
<p>£10.</p>
<p>http://www.chainreactioncycles.com/Models.aspx?ModelID=9911</p>
<p>And ride more, and wear it out :-)</p>
<p>Plus if its really 'tired', a new chain probably won't work too well.
						                            <category domain="https://singletrackworld.com/forum/bike-forum/">Bike Forum</category>                        <dc:creator>br</dc:creator>
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224947</guid>
                    </item>
				                    <item>
                        <link>https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224946</link>
                        <pubDate>Fri, 07 Jun 2013 11:11:46 +0000</pubDate>
                        <description><![CDATA[As above - something doesnt sound quite right there.
I would guess that even the 11 spd chain would physically work with a 9-10spd drivetrain, its only 0.1mm thinner, or 0.05mm each side of...]]></description>
                        <content:encoded><![CDATA[<p>Kind of. Obviously the 10 speed chain is narrower. I tried it and it wouldn't "sit down" in the chainring properly. Less than 0.5mm. But it did skip when under a lot of pressure.<br />
YMMV.</p>
<p>As above - something doesnt sound quite right there. </p>
<p>I would guess that even the 11 spd chain would physically work with a 9-10spd drivetrain, its only 0.1mm thinner, or 0.05mm each side of the chainring tooth - naff all.
                        <guid isPermaLink="true">https://singletrackworld.com/forum/bike-forum/10-speed-chain-on-a-9-speed-train-will-it-work/#post-5224946</guid>
                    </item>
							        </channel>
        </rss>
