My Lapierre hasn’t been feeling quite right for a little while. It rides ok on the XC stuff. It feels alright in the garage when I am trying to work out what’s wrong – yet it clatters around more than before in the rough. The rougher, the more noticeable. “Clattering” is about the best way I can describe the noise. Similar to once when my cassette was loose.
Everything seems tight. The cassette is locked on, the rear mech tension ok, neoprene chainstay protector on. The pivots seem ok, most of the bearings replaced last year,and shock serviced by Mojo with new bushings recently.
The only thing I can feel is, if holding the rear wheel (forcing it downward) to the ground and pulling the seatpost area, there is a very slight amount of play somewhere. Similar to when a shock bushing has gone (but given they’re brand new bushings, and you have to hold the wheel down to achieve the same sort of knock, I wouldn’t think it’s this?
Help!? Thoughts?
