I’ve had this problem, moved into new house in October with a wood burner but no dry wood left.
Thankfully wy wife’s uncle has a warm where a number of trees went down over the last few years and he gave us 1/2 ton of wood, the trouble is that only a third of it was dry enough.
I have a system where i use the dry wood to get the fire going and have 8-10 logs of the moister wood drying next to the stove. I also have a box by the boiler in the kitchen (hot water, not wife) where it is warm.
So a rotation really, go outside and get some wood from store, that box goes beside the boiler, the box i brought in previously by the boiler then goes to be put around the stove to finish drying out and then becomes the next nights dry food (hope that makes sense!)
It is difficult still sometime lighting, but found that with plenty of paper and dry kindling and the method above of having the stove door slightly cracked until it “flares” up works.
Not ideal, but resent paying for dry wood or solid fuels when i have free wood outside.
