Just built this up with a view to using it in the 'Puffer.
Weighs 12.1kg with Surly Black Floyd* tyres.
*In the race I will use lugged tyres - probably Surly Larrys.
Interesting choice of bars. I'd be really keen to hear what you've tried and what you thought of them all..
Could you mount disc levers on those bars, I'm wondering?
Magura Julies, specifically
What is the purpose of these "fat"bikes I keep seeing on here, why such big tyres, what they used for?
That looks comfy for badly-surfaced roads, not seen the Black Floyd tyres before.
I really want to ride one of these things
downs523 - Member
This sort of thing
And they will get you further through a peat bog or any soft surface than a standard bike.
Also surprising good on some technical stuff.
druidh - MemberI grew up riding offroad on dropbars (before mtb) so it simply feels more natural to me (especially on a singlespeed).
honourablegeorge - MemberNothing is impossible, but it would take some work - different diameter bars, and the shape of your levers would be different.
what rims are they - are they offset drilled
why dont you just buy a tractor ?
I too would like to know what rims and what forks?
I bought the rims 10 years ago in Oz for an intended overland 1,000km trip (no trails). Even then I was trying to get the widest tyres I could get.
Rims are ordinary drilling. Offset wouldn't work because they are heavily curved. Fork is a special order - wanted it as short as possible to avoid flex. However I nearly used my On-One carbon fork for this bike because it will just fit.
ancient - Member
OK, what size are the rims and hub.
Nice looking steed........
Ta, I can spot several things I intend to change, but first I'll get some miles on it.
40mm rims, front hub 10 year old Shimano Deore 100mm OLD still perfect, rear hub DMR Revolver 135mm OLD singlespeed disk.
26lbs for a hardtail with no Suspension or gears!?!?!?!?!? WTF why?
Just because janesy
Janesy - Member
So I can ride on surfaces where you would be pushing or carrying.
SAY NO MORE ....
SAY LOTS MORE!!
How about getting a ktm over the first gate you arrive at? :O)
I had a very short spin on this bike earlier today and its so light and lively. When i sit here thinking about what to write.. i can only say that it feels more normal than most 29ers that ive tried. You dont seem to notice the size of the tyres and the thing just floats along in silence.. You could drink a cup of tea riding this thing like you could happily drink a cup in the back of a rolls royce silver shadow! No spills,just thrills!
Steve McQueen the gate
jonnyvegas - Member
You're welcome to try
I used to ride stuff like that. They're only good for annoying ramblers and digging big holes.
Honestly don't understand "Surly Black Floyd* tyres."
Care to explain Epi (or anyone else who's used them)?
Honestly don't understand "Surly Black Floyd* tyres."Care to explain Epi (or anyone else who's used them)?
I used to use Maxxis Holy Roller tyres, which aren't quite the same (only 2.4") but do grip amzingly well in all but mud, people forget that most of the grip comes from the interaction between the rubber compound and the ground, the tread only makes a difference when the gound's unstable, I'm guessing that an even bigger tyres spreads the shear stress over a larger area thus the ground is less likely to give way?
So useless in mud but grear in anything hardpacked or larger than gravel?
I didn't make any of those tags. ****.
GW - Member
Honestly don't understand "Surly Black Floyd* tyres."...
They're a new release so I thought I'd try them. Just got them.
I figured they might be good for general road and offroad gravel, and then with a drop in pressure, softer stuff. Eg, I fancy doing the Great Glen Way down to Ft Oggie, cut across the Corrieyairack, and then amble home up the old A9, or stuff like going C-C from Ardross to Ullapool and returning by road. They're not what you'd pick for singletrack only use, but I was hoping that where are any lengthy road/dualtrack stages the gain on the swings exceeds the loss on the roundabouts.
In practise they seem good. Just done the top half of Contin and they roll nicely even on the singletrack. It felt strangely similar to my CX bike for response.. Spin out in really soft mud, but actually better than I expected. Much faster (IMO) on hardpack than lugged tyres. The smooth tread means soft ruts need more care because they like to slip back down. Lower pressures may make that easier though - I was running 20psi, and I think most people run much less in the Floyds.
However, they'll be coming off the bike soon (until spring) and I'll be using Larrys or BFLs for Winter.
grum - MemberFigured that when I saw "tagged by Grum"
If this is a bike built to be niche, it's waste of effort because there's rarely any other riders around to be suitably awed where I'm out riding it.
It's built to fit, built for purpose, and it won't be seen leaning outside a cafe.
This is a very interesting bike. What are we calling it? Humungous-cross? Obese-cross? Bloater-road?
What gear are you running?
You can't blame anyone but yourself for your reputation grum
BigDummy - Member
This is a very interesting bike. What are we calling it?...
Tractor (with acknowledgements to Ancient)
(My entry in the 'Puffer is Square Wheels Single Speed Tractor Club)
flashes - Member
32/20 - it's a magic ratio, there's no adjustment on the dropouts. Just happens to be about right for the purpose for which I built the bike.
They're a new release so I thought I'd try them. Just got them.I figured...
Ah.. bought on a very expensive whim, fair enough, we all have them..
sound like a Jack of "some" trades master of none kinda deal tho.
Black floyds. Stick em on ya fatty... Old motorcycle leathers off eBay. Full face and gloves and thumb a lift up alp duez. Get your knee down in the Switchbacks.
Or bomb around the park.
I've come to the conclusion the Floyds need to be on my geared bike, or maybe dingle speed this one.
In the last few days I've been poring over the map checking out distant trails. There's lots I could ride to on the road and higher gearing for the road portion would make that more feasible.
CTBM's idea has merit too. Be a nice ride down the A9 from the Slochd to Inverness, or Braemore on the Ullapool road. And of course there's always Applecross - might need a fairing for extra gnarr.
Black floyds. Stick em on ya fatty... Old motorcycle leathers off eBay. Full face and gloves and thumb a lift up alp duez. Get your knee down in the Switchbacks.and get overtaken by loads of roadies with nothing but a slither of spandex for protection (I talk from experience)
Epicyclo, your photos are making me want a fat bike more and more.
Please stop posting as I have a poorly bank account already.
Epicyclo, what fork is that? doesnt look like a lot of clearance if you put a nobblier tyre on
downs523 - MemberWhat is the purpose of these "fat"bikes I keep seeing on here, why such big tyres, what they used for?
And this
Merseyside Fat Bike United by Johnclimber, on Flickr
Just Because by Johnclimber, on Flickr
Even though it knackers up your bottom bracket, 1500miles+ and 11 months of beaches I suppose isn't a bad life for it's bog standard one
You must log in to post.
