All mechs will be like this soon, this tech will trickle down as its one of the “BIG S`s” better ideas. SRAM are currently “adopting” the idea too.
Alot of people dont realise you can adjust the tension in the mech by removing the cover and using the tool supplied (kept inside the mech!) you can loosen the “lockout” right off.
This stops the stiffer shifting action when the gold lever is engaged. It doesnt need to be set on full lock or “stiffest setting” to stop the cage from moving.
You can pick one up for £125 on CR using £10 off this weekend! Bargain!
