Short version – trying to figure out if I can run a left XTR M985 crank arm on an M980 chainset, and if so, what the effect is.
Long version – Merlin cancelled my M980/Stages 180mm order as they had their stock levels wrong. They have the 180mm M985 Stages left arm available. They and Stages say it is only for the M985 chainset not the M980. The difference between them is 6mm of Q factor (and a different BCD, that’s irrelevant here), but a) would the left arm of the M985 physically fit on the M980 chainset, are there any mechanical differences in the interface, and b) would it mean the left Q factor is 3mm less than the right?
Given I ride roadbikes through to fat bikes with 100mm BBs, have had adjustable chainline and asymmetric BBs before, and generally am not very princess and pea about bike setup, if it fits/works am I likely to notice this?
Thanks!
