The cranksets are both the same, with the little tabs that go on the end of the spider differing for single and double rings.
I bought a double after being told by the shop I could just swap out the rings for a single.
Found out I could, but these tabs made for double rings stopped the single ring mounting properly and meant i had to spend another £80 – yes really – for the correct tabs.
If I was doing it again, I’d spend a litle more and get the correct crankset.
PS. I used the genuine matching single ring. It might work differently with a after market n/w ring, but I suspect it will have similar clearance problems.
