Viewing 11 posts - 1 through 11 (of 11 total)
  • XTR CHAINSET FITTING
  • porcaro
    Do I need the TL-FC35 Tool for fitting a M970 XTR chainset? Or is this tool simply for the removal?
    foxyrider
    No – just removal if you use say fine nose pliers to put the last nylon thread protector ring (crank cap) in at the end.
    I wrote this article if its any use?
    http://www.cyclistno1.co.uk/features/maintenance/servicing-xtr-cranks.htm
    porcaro
    Very good article, thanks for that. Glad I don’t need that TL-FC35 it’s so expensive!
    foxyrider
    I got mine 2nd hand from STW classfieds – BTW you get the tool with teh full retail XTR crankset but not with an OEM set as I found out 😉
    porcaro
    I managed to get my XTR 970 chainset for under £100 on ebay with bottom bracket and it was boxed! Now that’s a bargain. Only had to buy a TL-FC32 for £12 to fit the bottom bracket.
    wwaswas
    I’d look at getting that tool sooner rather than later – when you do need to remove the chainset you’ll find everywhere is out of stock…
    porcaro
    Cheapest I could see for that tool was £29.99, anyone seen it cheaper?
    rob2
    I’ve got one if you want to borrow it (reading oxfrod area)
    foxyrider
    £24 from winstanleys but I would suggest putting up a wanted in STW or go to ebay 🙂
    Edit: as above if you are near Exeter I have one you can borrow if you ever need it 🙂
    wwaswas
    starbike.com have them in stock for 22euros – not sure what they charge for postage, though.
    alcolepone
    anyone around derby with one?
The topic ‘XTR CHAINSET FITTING’ is closed to new replies.
