Teej, I said they CAN be a git to change. The first time I did mine they were, second time not so bad. You can’t disagree that £20 a set is more than a 50p bag of bearings, and out of 5 Pro2s we’ve had, only one has had bearings last more than a year. Some of the fronts are terrible. And it’s not just me either, I’ve known fronts to go in 3-4 months on Pro2s. And if you’ve had to change a set, they’ve not been lasting you ‘many years’ either becasue they’ve only been in production what, 5-6 years? XCs seem to last 4 years or more…..
If I still had the pic of the XC vs Pro2 bearings I’d post it, becasue it explains why very well indeed. 🙂
Personally, I don’t think the perfect hub has been made yet. If there was a £60-ish loose C&C bearing hub with a rebuildable freehub, replaceable races and swappable axles, I’d buy it right now! 🙂
By coincidence, I’ve got a set of Kaese’s Katec bearings to go in Mrs PPs Pro2s this weekend. They’ve just lunched their 2nd/3rd set (I forget) of bearings in 3 years on a bike that hardly gets ridden half the year. Damn thing uses more bearings than brake pads, and it’s still on it’s origninal drivetrain!
