Can you get a cover for shifters to where the optical gear display is removed.
Bike Forum
Xt shifter blank/cover
Posted 5 months ago #
The blank is inside when you take the optical display off.
Posted 5 months ago # -
Eh inside what? do you mean tits part of the bit you remove
You can't say that around here!
But, to answer your question, remove the little screws, take off he indicator window section, remove the little cover inside it, and fit the cover using the little screws. Job done (2 mins).
Slip of the finger. Thanks for that
bryan-g- - Member
Slip of the finger. Thanks for thatCareful, that can land you in the sh....
Reply
You must log in to post.
