Ive recently converted my M8000 1×11 cranks to 2×11, the chainring spacing seemed exactly the same as a purchased 2×11. I actually used the m7000 slx rings on it, as these are steel and plastic, rather than the XT’s alloy rings, so hopefully will last a bit longer.
one thing i did notice when setting up the derailleurs was that the chain kicked inwards at a certain point of the crank turn as it went around the large chainring – I eventually found the reason to be the small chainring spacer that sits behind the crankarm, to stop the chain dropping behind it, was actually a few mm longer than the gap, and was actually pushing against the chainring, causing it to deflect – a few minutes with the dremel soon sorted it. – Something to be aware of though, might be because the rings were from a non boost slx crank, and the XT was boost?
