Viewing 3 posts - 1 through 3 (of 3 total)
  • XT M756 hub conversion to 12mmx142mm?
  • chugg08
    Sorry, I’m sure this will have been asked but I couldn’t find a ref to it.
    Has anyone converted, or does anyone know if it is possible to convert either a rear XT M756 hub or Deore M525 hub to the 12mm x 142mm standard?
    Thanks in advance.
    FOG
    When I enquired if you could convert 756 to the larger DT q/rs [10mm I think] I was told it was impossible so I would think the same applies to the 12mm x 142mm
    chugg08
    Cool, thanks. It was worth a try.
    Doug
The topic ‘XT M756 hub conversion to 12mmx142mm?’ is closed to new replies.
